Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Unimat lash-ups
Hybrid View
    Mar 2018
    New England, USA
    threesixesinarow's Tools
    Unimat lash-ups
    Another Unimat lash-up:
  2. The Following 2 Users Say Thank You to threesixesinarow For This Useful Post:
    Home-PC (Jun 6, 2022), old_toolmaker (Apr 12, 2018)
    Dec 2017
    Cape Coral, FL
    old_toolmaker's Tools
    Hi threesixesinarow,
    I am always interested in the work of others and your work is always intriguing! The pictures are invaluable and give me ideas I could use myself.
    Did you cut the dovetail for the vertical attachment in an existing Unimat head stock? Or did you make an entire new head stock? Lastly, what is the machine it is mounted on?
    Dick
    Dick
    Links to some of my plans:
  4. The Following User Says Thank You to old_toolmaker For This Useful Post:
    threesixesinarow (May 10, 2018)
    Mar 2018
    New England, USA
    I’m glad they’re useful.
    It’s new but there’s enough material at the bottom of a regular headstock to mill one the same way. A more attractive option might be bolting the front dovetail to the existing bottom which would only make it 5mm higher and you wouldn’t lose the indexing wing or the mounting post.
    The rear dovetail is separate and is what clamps the headstock to the slide.
    Here is a clearer view of that little machine but with a different spindle. Travels are about 4 x 3 x 2”.
  6. The Following 3 Users Say Thank You to threesixesinarow For This Useful Post:
    Home-PC (Jun 6, 2022), Jon (Apr 13, 2018), Paul Jones (May 9, 2018)
    Mar 2018
    New England, USA
    A funny Unimat setup.
    Instead of plates I just use a two position index with a train of mini lathe change gears to set the number of divisions, or approximate ones like 23 in the second picture.
  8. The Following 3 Users Say Thank You to threesixesinarow For This Useful Post:
    Home-PC (Jun 6, 2022), old_toolmaker (Jun 15, 2018), Paul Jones (May 26, 2018)
    Mar 2018
    New England, USA
    Unimat cross drilling adapter, with spindle brake shown at http://www.homemadetools.net/forum/n...ni-lathe-67849
    Last edited by threesixesinarow; Jun 15, 2018 at 11:21 AM. Reason: fix old attachment
  10. The Following User Says Thank You to threesixesinarow For This Useful Post:
  11. #6
    Mar 2018
    New England, USA
    Here is the angle iron cross drilling attachment with the dovetail Unimat headstock, as well as the rotating mount for the smaller spindle shown in the second picture of the little mill.
    Unimat lash-ups-fef9f60b-23ba-45ac-bbed-6728e134d91f.jpgUnimat lash-ups-millingvise.jpg
    That also works as a base for the little vise.
  12. The Following 4 Users Say Thank You to threesixesinarow For This Useful Post:
    Home-PC (Jun 6, 2022), Jon (Jun 15, 2018), PJs (Jun 16, 2018), Seedtick (Jun 15, 2018)
  13. #7
    Mar 2018
    New England, USA
    Thanks, Dick,
    I only just learned about the small metal slides you can buy now reading on a different forum-they look alright, or at least better for something like this than the plastic and aluminum ones I saw before.
    The table on my homemade slide is a lot narrower than those, though, and the whole thing’s about an inch shorter and has some things I didn’t see available in other designs. It made a big mess but the cast iron bar cut nicely and I didn’t have to worry about voids like on the base of the vertical slide.
    As for versatility, we’ll see! It’s harder for me using ordinary work holding tools at this scale, and so far it has only been really useful for a few tasks, like making cutters. Some kind of toggle clamp system and an x-axis lever feed will help a lot for the repetitive things I want to do with it-so far it has been easier setting up to do them on a lathe (with Unimat parts, too), like cross drilling and even slotting.
    ⁃ Clark
    Unimat lash-ups-wmmillcrossslidedetail2.jpegUnimat lash-ups-withoutnohead.jpg
  14. The Following User Says Thank You to threesixesinarow For This Useful Post:
  15. #8
    Thanks threesixesinarow! We've added your Dividing Setup to our Measuring and Marking category,
  16. #9
    Thanks threesixesinarow! We've added your Unimat Headstock Adaptor to our Lathe Accessories category,
  17. #10
    Mar 2018
    New England, USA
    Rotary broaching using a Unimat.
    Unimat lash-ups-9c53e494-d618-4efe-b4e7-f581465e0995.jpgUnimat lash-ups-2d28e581-4c16-4007-9968-9505976f7438.jpg
    Makes a driving nut to fit an old Dremel collet chuck screwed onto a stationary, emergency moto-tool, for a flex shaft.
    Last edited by threesixesinarow; Jul 3, 2018 at 02:42 PM. Reason: Add picture of what the broach did
  18. The Following 5 Users Say Thank You to threesixesinarow For This Useful Post:
    Home-PC (Jun 6, 2022), Jon (Jun 27, 2018), Paul Jones (Aug 10, 2018), PJs (Aug 10, 2018), Shanty (Aug 9, 2018)
