Results 1 to 4 of 4
Thread: Unimat SL Tailstock Lever Action Clamping Screws
    May 2014
    Del Mar, California
    Paul Jones's Tools
    My 3” swing Unimat SL lathe uses M6-1 cap head socket screws for locking and clamping the tailstock. I replaced the M6 cap head socket screws with my version of clamping screws with swing-out levers to apply more torque. The swing-out levers eliminate using Allen wrenches.
    The clamping screws were machined from 3/8” dia. 1018 CRS bar, the M6 threads cut with a tailstock mounted die, and the knurl is 21 pitch (whereby the 3/8” dia. was reduced to 0.364 before knurling). The swing out levers are 0.062” x 0.365” x 1.20” machined with 11/64” radii from 1/16” steel support rails salvaged from electronics rack panels. The slots in the clamping screw heads are 0.063” wide by 0.450” deep. The levers are retained with 3/32” roll pins shortened to fit.
    More information and photos about the improvements to the Unimat SL lathe can be viewed at Homemade Lathe Modifications .
Name:	Lever action clamp screws for Unimat SL tailstock.jpg
ID:	6929   Click image for larger version.
Name:	New lever action clamp screws for Unimat SL tailstock.jpg
ID:	6932   Click image for larger version.
Name:	Unimat SL Lever Action Clamping Screws for headstock and tailstock.jpg
ID:	9677   Click image for larger version.
Name:	Original clamp screws for Unimat SL tailstock.jpg
ID:	6934   Click image for larger version.
Name:	Unimat SL tailstock with lever action clamp screws.jpg
Name:	Layout for radius ends to clamping levers.jpg
ID:	6935   Click image for larger version.
Name:	Cutting a slot in tailstock clamping screw.jpg
ID:	6939   Click image for larger version.
Name:	Applying 21 pitch knurl to 0.364 dia rod.jpg
ID:	7032   Click image for larger version.
Name:	Drilling cross hole in tailstock clamping screw.jpg
ID:	6937   Click image for larger version.
Name:	Fixture for holding tailstock clamping screw for cutting slot.jpg
  2. The Following 11 Users Say Thank You to Paul Jones For This Useful Post:
    12L14 (Jul 31, 2019), Altair (Dec 20, 2015), dshookowsky (Jul 20, 2019), emu roo (May 9, 2026), jjr2001 (Sep 1, 2016), Jon (Dec 21, 2015), kbalch (Dec 20, 2015), PJs (Dec 21, 2015), Ralphxyz (Sep 20, 2022), uv8452 (Sep 16, 2022), zarembak (Jul 19, 2019)
