Results 1 to 10 of 19
Thread: Using Circular saw blades on Miter Saw
    made2hack's Avatar
    Jan 2018
    made2hack's Tools
    Hi all,
    I've got a technical question of sorts. I have both a circular saw and miter saw. The circular saw uses 230mm (9") blades but the miter uses 255mm (10") blades. Can I use circular saw blades on the miter saw?
    Aside from the fact that they spin in the other direction, would there be other issues with this? The bore is the same 25.4mm (1").
    There are many stainless steel blades for circular saws that come in 230mm (9") and 305mm (12") sizes for circular and chop saws but none that I have found in 255mm (10") size for miter saws. I don't know why that is.
    Thanks for your input,
  2. The Following User Says Thank You to made2hack For This Useful Post:
    Seedtick (Nov 5, 2018)
