Results 1 to 10 of 10
Thread: Using Rosin To Start a Philips Head Screw
  1. #9
    Yes Marv's duct seal makes good ballistic putty. An inch seems to stop any pellet, even my 5mm's. Sealing wire entry is a common use. Real important marine use inside their stuffing tubes for watertight integrity.
    Cleansers add 'bite' to screwdriver bits. A bit of torn off aluminum foil can help with Phillips or straight screw slots. Both leave particles, not always electrically or mechanically copacetic.
    Rosin, warmed with a butane lighter makes a nicely brittle glue that really holds fasteners.
    Finding modeling clay is worthwhile; holds thread wires, replicate fillets and radii, [can slice for comparators], reveal clearance when fitting parts, apply underside of thin sections to dampen vibrations while subtractive machining, adheres on most surfaces - weighs easily for static balancing, shelved object pressed into 3 small cone 'feet' might avert loss during earthquakes. Don't have a tube mic? With a little clay and small bearing ball, now you do.
    I keep a lump in prescription container for the thread wire trick. In reality it's plumbers putty, a nice plain gray color. Not big fan of pink, neon green or white. Brown has a lot of practical joke applications...
    Last edited by Toolmaker51; Dec 4, 2018 at 05:41 PM. Reason: 1st today...edits make me feel alive!
  2. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    PJs (Dec 5, 2018)
