Results 1 to 10 of 19
Thread: Using stamps for numbers and lettering.
    Jul 2012
    Cheshire, UK
    drmico60's Tools
    It is not easy to achieve a good spacing of numbers and letters when using stamps to mark metal.
    A little trick that I have used several times is to first print out the text onto a paper label using a similar font and character size to the stamps.
    The metal to be stamped is set up on a solid surface with a vertical straight edge to guide the stamps in a straight line. Stick the label onto the metal just in front of the straight edge and use the text to guide the position of stamp. The stamp can be pressed firmly into the label with hand pressure and this leave an indent in the label but not the metal so you can check the position. Once satisfied with the positioning then the stamp is repositioned in the label indent and hit firmly with a hammer to indent tne metal.
  2. The Following 26 Users Say Thank You to drmico60 For This Useful Post:
    12L14 (Jul 31, 2019), blkadder (Mar 20, 2019), bruce.desertrat (Jan 4, 2019), DDoerschuk (Mar 20, 2019), Eaglewood (Mar 20, 2019), elmer139 (Nov 26, 2021), emu roo (Oct 22, 2024), greyhoundollie (Mar 20, 2019), hardlylook (Oct 22, 2024), high-side (May 7, 2019), homey_g (Aug 25, 2021), J.Pierce (Aug 25, 2021), Jon (Jan 4, 2019), LMMasterMariner (Jan 16, 2019), mr mikey (Oct 23, 2024), nova_robotics (Aug 24, 2021), oldpastit (Jan 5, 2019), Paul Jones (Jan 13, 2019), PJs (Jan 5, 2019), Ralphxyz (Oct 27, 2022), rgsparber (Jan 4, 2019), rlm98253 (Jan 4, 2019), rossbotics (Jan 5, 2019), Scrounga (May 3, 2024), Seedtick (Jan 4, 2019), techcollect (Aug 25, 2021)
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    This method works great. I found that Arial Unicode MS 14 is a close match to my Harbor Freight stamp set. I print out the text on my DYMO LabelWriter 450. Since all of the text to be stamped is visible, I can use a given stamp at every position that needs it. That way I don't have to pick up the same stamp twice. Does speed up the process a bit.
    Now, if I could just be more consistent with my imprint depth...
    Thanks drmico60,
    Rick
    Rick
  4. The Following 2 Users Say Thank You to rgsparber For This Useful Post:
    bruce.desertrat's Tools
    Duh! brilliant and simple idea! I've been meaning to remake our dogs's name&phone ID tags, since their existing ones are kinda beat up, and I always seem to make them look more like a ransom note than anything else :-)
  6. The Following 3 Users Say Thank You to bruce.desertrat For This Useful Post:
    Paul Jones (Jan 13, 2019), PJs (Jan 5, 2019), Toolmaker51 (Jan 6, 2019)
    Rick
    It would not be too difficult to make some form of stamp holder with a vertical extension to hold some form of weighty block at an appropriate height, on a slide. Add a trigger (for example) release and hey presto - even indents every time. A little experimentation prior to building would soon get the mass and height of the block determined.
    Of course this will only work on surfaces that you can arrange to be horizontal. Although a bell crank could turn the force.
    For non horizontal surfaces you could replace gravity with a solenoid or maybe a pneumatic cylinder into which you could rapidly dump a set volume of air at an appropriate starting pressure.
  8. The Following 3 Users Say Thank You to tonyfoale For This Useful Post:
    Thanks drmico60! We've added your Stamping Guide to our Miscellaneous category,
    as well as to your builder page: drmico60's Homemade Tools. Your receipt:
  10. #6
    Thanks drmico60,
    Rick
    Rick,
    I was just idly browsing through a tools listing, not looking for anything in particular when this popped up
    https://www.ebay.es/itm/38pc-AUTOMAT...sAAOSwzJ5XUrxZ
    Something like that could be the answer to your even imprint problems, I guess that it works just like an automatic centre punch.
  11. #7
    I have one of those sets, it's not exceedingly powerful, and did not make decent impressions in steel; Also the letters are quite tiny. Yes, it's essentially a center punch with a stamp holder instead of pointy bit.
    Maybe something like this Spring Center Punches & Nail Sets - Lee Valley Tools with a holder for the stamp instead of a punch on the business end.
  12. #8
    Jul 2012
    Cheshire, UK
    drmico60's Tools
    The problem with stamping uniformly is not solved by having a consistent pressure/impact. This is because each letter/number has a different total line length and therefore requires a different pressure. For example the length of the lines making up the letter H is nearly three times the length of the lines making up the letter I so to stamp an H needs nearly three times the pressure to get the same indent depth as stamping a letter I. Each letter is different so there require different pressure on the stamp.
    Mike
  13. The Following 2 Users Say Thank You to drmico60 For This Useful Post:
    Jon (Jan 9, 2019), rlm98253 (Oct 23, 2022)
  14. #9
    Quote Originally Posted by drmico60 View Post
    Mike
    How come the flipping obvious is so often hidden in plain sight?
  15. #10
    Supporting Member blkadder's Avatar
    May 2012
    Florida, USA
    I can't believe that I missed this when it was first posted. I have not had great luck with my stamping projects (usually home built firearms), and this would pretty much solve the issues that I was having. It would also be useful to make templates for etching information into metal. Thanks for posting this.
    Ron
    ...Semper Fidelis...
