A good way to guard against breakage is to make a fitted sleeve over the tap encapsulating the shank and at least the bottom and back thread runs
What I would do would be to bore a piece of round stock to fit the shank then bore out the thread depth slice away about 120° of the now threaded end the length of the threads. Mow screw the tap into the holder. shank first once it is threaded all the way in drill and tap for a couple of grub screws to contact in the flutes clamp this in your boring bar holder or tool holder, you now have made a tool you can thread with without breaking the tap.
