Very impressive work, I always look forward to your new creations!
- How did you mill an accurate V-slot in the edge of the block? (prior to picture #3). It looks relatively deep.
- about how much material comes off in the grinding stage?
- When you permanently dowel pin parts together like this, are the pins interference fit on both holes, or just one, or maybe none? I guess I'm wondering if the heat treating process might alter dimensions a bit from the machining stage.
