Results 1 to 4 of 4
Thread: Vacuum Brake Bleeding
    JeffEck's Avatar
    Jan 2017
    Kansas
    JeffEck's Tools
    Vacuum operated brake bleeder. I purchased a vacuum pump on surpluscenter.com and added a steel vacuum tank in line. I plumbed all lines to the tank on the top and a drain valve on the bottom, that way fluid should not be able to get to the pump without an operator error. I put a vacuum gauge on the tank to know everything is working properly. From the tank I used a small hose that was stiff enough to not collapse under a vacuum but stretchy enough to slip on the blake bleeding nipple with a tee and go to both wheels on the rear or front, depending on which end I am bleeding. I turn the pump on and then open the bleed nipple and monitor the brake mastercylinder reservoir and refill as brake fluid flows. I usually run extra fluid through the system to flush it and make it all fresh and new. I hope this helps.
    Vacuum Brake Bleeding-20200924_163746.jpgVacuum Brake Bleeding-20200924_163806.jpgVacuum Brake Bleeding-20200924_163802.jpgVacuum Brake Bleeding-20200924_163809.jpgVacuum Brake Bleeding-20200924_163827.jpg
  2. The Following 2 Users Say Thank You to JeffEck For This Useful Post:
    Jon (Nov 12, 2020), Sleykin (Nov 10, 2020)
    Apr 2016
    I never knew a vacuum break needed bleeding oh well, if I fine a vacume break that needs bleeding Ill look for this and watch.
    Thanks JeffEck! We've added your Brake Bleeder to our Brake category,
    as well as to your builder page: JeffEck's Homemade Tools. Your receipt:
    JeffEck's Avatar
    Jan 2017
    Kansas
    JeffEck's Tools
    You are joking, right? Automotive brakes.... Not my Cincinnati Pressbrake, that was just a clean spot for a photo.
