Results 1 to 10 of 13
Thread: Variable Speed Tread Mill D.C. Motor Conversion Shop Fox Drill Press.
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Variable Speed Tread Mill D.C. Motor Conversion,with DC power supply for Shop Fox Drill Press.
    Variable Speed Tread Mill D.C. Motor Conversion  Shop Fox Drill Press.-002.jpgVariable Speed Tread Mill D.C. Motor Conversion  Shop Fox Drill Press.-003.jpgVariable Speed Tread Mill D.C. Motor Conversion  Shop Fox Drill Press.-007.jpgVariable Speed Tread Mill D.C. Motor Conversion  Shop Fox Drill Press.-006.jpg
  2. The Following 5 Users Say Thank You to Captainleeward For This Useful Post:
    davidhoneybadger (Jan 4, 2018), EnginePaul (Jan 7, 2018), Paul Jones (Jan 3, 2018), rossbotics (Dec 28, 2018), Seedtick (Jan 4, 2018)
    The magic is in the third picture. I'd use these if I could get a "Tread Mill Controller for Dummies" instructable that I could just "do" without having to understand anything electrical. Have a couple of motors and want to do a 2 x 72 sander.....
    Supporting Member Al8236's Avatar
    Dec 2014
    Kendall Washington
    Al8236's Tools
    Quote Originally Posted by obt@charter.net View Post
    Try this video it's as simple as I have seen I'm about the same when it comes to electrical and this worked for me!
    From the time you're born till' you ride in a hearse, there's nothing so bad it couldn't be worse!
  5. The Following 2 Users Say Thank You to Al8236 For This Useful Post:
    Captainleeward (Jan 4, 2018), EnginePaul (Jan 7, 2018)
    Jul 2014
    I removed the fly wheel just to be on the safe side and the motor works fine I have these motor and controllers on my lathe, mill and my drill press.
    You can buy these components on ebay for cheep 50 for the motor and 50 for the controller. my controller does not have that large transformer on it.
    Thanks to AL8236 for a great video...:O)
  7. The Following User Says Thank You to Captainleeward For This Useful Post:
    Al8236 (Jan 6, 2018)
    Quote Originally Posted by Captainleeward View Post
    ..... my controller does not have that large transformer on it.
    I think that you will find that the "transformer" is a just a choke (inductance) which is used to filter or smooth the current through the motor. The speed control system works by chopping part of the AC cycle which at lower speeds and when rectified results in a series of narrowed pulses rather than the wider ones from a rectified full sine wave. Neither are smooth DC.
    These are DC brush commutated motors which prefer feeding on smooth DC rather than out of phase rectified and chopped AC. At any given speed the commutator segments pass under a brush at a certain frequency which mostly will be out of phase with the supply frequency. The choke helps by evening out the current pulses. These motors run much smoother and quieter with the choke in series.
    The above applies to TRIAC controllers which are the only type that I have seen in treadmills, but if some controllers are based on a PWM system then there would be less need for a large choke due to the much higher frequency of the pulses. 1000s of times higher.
  9. The Following 2 Users Say Thank You to tonyfoale For This Useful Post:
    Captainleeward (Jan 5, 2018), DIYer (Jan 5, 2018)
  10. #6
    bigtrev8xl's Avatar
    Jul 2016
    Low Cost DC Motor Controller For Treadmill....
    I've just ordered the parts off ebay, there's lots of similar videos on youtube
  11. #7
    Jul 2014
    Hi Tony Foale, WOW Thanks for clearing that up for me I was wondering what that transformer was doing there. you can be friends with me if you wish.
  12. #8
    ha, ha. I accept, can't have too many friends. On another thread I promised that I would make a post describing several methods of controlling motor speed but I have not made the time for it yet.
    For my first use of the treadmill motors I used the treadmill controller but they have delays and other safety features built-in which make those controllers less suitable for controlling machine tools so I make my own. Maybe this weekend I'll try and finish that post describing motor control.
  13. #9
    Thanks Captainleeward! We've added your Drill Press DC Motor Conversion to our Drilling and Drill Presses category,
  14. The Following User Says Thank You to DIYer For This Useful Post:
    Captainleeward (Jan 7, 2018)
  15. #10
    Dec 2018
    Thank you, very helpful. What model/brand treadmill was used and what is the model of the speed controller. Looks like it might be a MC 60
    Thanks again - Nick
