PJs (Oct 29, 2018)
That is an ingenious build! The ratcheting pawl mechanism to wind the spool (2:21) and geared proportionally to the drive and feeds is off the charts. Although the drive motor (1:03 starter motor?) with the RT angle gear box is a modern addition, it all works like a charm...and still someone needed to gather and cut the straw! Wow!
And I think Mrs. PJ needs one of those Yarn Recovery systems...pretty cool but looks complex to thread to start the process.
Mark Twain
PJs (Oct 30, 2018), Seedtick (Oct 29, 2018), Toolmaker51 (Oct 29, 2018)
PJs (Oct 30, 2018)
PJs (Oct 30, 2018)
Roger that Frank! The lace machine is off the charts as well. I can't seem to find a vintage of the machine but the rotating spools and timing with the fingers to what ever pattern is being produced has to be top in its day at those speeds. Also notice the use of the flex shaft coupler on the hand wheel shaft at :10!! Truly a Franz Mesmer special!!
Mark Twain
Beserkleyboy (Nov 3, 2018), bigtrev8xl (Nov 9, 2018), emu roo (Jul 28, 2025), PJs (Oct 30, 2018), Seedtick (Oct 30, 2018), volodar (Nov 4, 2018)
Even more impressive at .25 speed on YT!
But this one for a 3 phase stator winding is even more Mesmer...Note the automated Hi-Pot test toward the end and the tie wrapping system is prestidigitation at is finest.
4:45 vid...
Mark Twain
