Results 1 to 8 of 8
Thread: Very poor mans cnc setup
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    This is the only way I could think of to machine six internal radius on a gear for my Foden Steam Wagon. As can be seen from the photos I used a rotary table in conjunction with an indexing head. With some careful setting, up I was able to use the rotary table to cut the radius between the two-known start and finish angles (hand to calculate) and the indexing head simply allowed for the gear blank to be positioned at the six equally spaced positions. The rotary table, after cutting the first radius was returned to its original start position and the indexing head moved to the next location, this radius was then cut to the same start/finish angle as before and so on until all 6 radiuses were cut.
    A CNC machine would have made this a whole lot easier, but as I don’t have one the challenge was overcome with a little bit of thinking outside the box.
    Very poor mans cnc setup-dscf1208.jpg.opt652x489o0-0s652x489.jpg Very poor mans cnc setup-dscf1210.jpg Very poor mans cnc setup-dscf1211.jpg.opt652x489o0-0s652x489.jpg
    Bottom left gear, finished with the six internal radius cut
    Thank you for viewing
    The Home Engineer
  2. The Following 24 Users Say Thank You to thehomeengineer For This Useful Post:
    bigtrev8xl (Feb 17, 2018), brianpoundingnails (Jun 13, 2018), BrianW (Jul 23, 2020), davidhoneybadger (Jun 13, 2018), drivermark (Feb 17, 2018), emu roo (Feb 19, 2026), FEM2008 (Jul 24, 2020), jjr2001 (Feb 16, 2018), johncg (Oct 16, 2022), Jon (Feb 16, 2018), Kevic (Jun 15, 2018), MeJasonT (Oct 11, 2018), mwmkravchenko (Feb 16, 2018), nashty1 (Feb 16, 2018), NortonDommi (Feb 17, 2018), Papa Bill (Feb 17, 2018), Paul Jones (Jun 13, 2018), PaulM (Feb 17, 2018), Philip Davies (Feb 28, 2026), PJs (Feb 16, 2018), Ralphxyz (Apr 21, 2023), Seedtick (Feb 16, 2018), Toolmaker51 (Jun 13, 2018), winmac (Oct 15, 2022)
    Thanks thehomeengineer! We've added your Internal Radius Cutting Method to our Machining category,
    Supporting Member Radioman's Avatar
    Jun 2018
    Massachusetts
    Radioman's Tools
    Beautiful work! I wish my mind was as dialed in as yours.
  6. The Following 2 Users Say Thank You to Radioman For This Useful Post:
    emu roo (Feb 19, 2026), thehomeengineer (Jun 14, 2018)
    Supporting Member brianpoundingnails's Avatar
    Jun 2018
    brianpoundingnails's Tools
    Necessity is definitely the mutha#%&er of invention.
    Hand, Head and Heart(mostly hands)
  8. The Following 2 Users Say Thank You to brianpoundingnails For This Useful Post:
    How many times we think "I don't have a CNC, but I want to make..."
    It's good to run into that, if next thoughts are "...but I have a _____ and ______..."
    I figure translation is "I'll do what THEY would have had done".
    Milling machines hum along doing certain things, but like homeengineer demonstrates here, tooling really makes them sing.
    Don't let automation erase creativity. Let desire or need pull the strings.
  10. The Following User Says Thank You to Toolmaker51 For This Useful Post:
  11. #6
    Supporting Member carl blum's Avatar
    Nov 2021
    Charleston, South Carolina
    carl blum's Tools
    Hi Gang:
    Before CNC I used a cross slide rotary table to make a punch like a kidney bean. Still have the slug.
    All the slides make for a bulky tool, but it worked:
    With in its range you can move the center of rotation anywhere you need. Takes a bit of planning and set up, but it was fun.
    Carl.
  12. The Following 2 Users Say Thank You to carl blum For This Useful Post:
    emu roo (Feb 19, 2026), thehomeengineer (Feb 15, 2026)
  13. #7
    Berkshire UK
    Wow I can see lots of opportunities if I had one of those. Thank you for sharing. I will have to keep my eye open for a x and y table that could be adapted. Another tool which only appears in the USA is a Volstro Rotary Milling Head which looks very interesting but very expensive. Never seen one in the UK
  14. The Following User Says Thank You to thehomeengineer For This Useful Post:
  15. #8
    Nov 2021
    carl blum's Tools
    Hello Home Engineer:
    From your photo it looks like you are building a Live Steamer! I've found a large scale (7.5") railroad in South Carolina and while I don't think I'll ever build a locomotive, I do have a hand car:
    Actually I have two and a flat car. Carl.
  16. The Following 2 Users Say Thank You to carl blum For This Useful Post:
