I haven't done the cfm math. the engines new are 23 to 1. interfiernce fit.( the top of the piston is basically into the dish in head). timing is critical or the valves will hit the piston. I see principle behind the 1to 1 in above post. getting a belt tensioned enough not to jump will be the hard part. if I could find an industrial unit that I could turn with the volks diesel that would be ideal. 50 cfm at 70- 100 psi will sand blast well. with a big nozzle for sand . everything is proportional smaller nozzle higher pressure lower cfm. less media used longer time to do work. thei is a flla from Tasmania posted a pic of a diesel he's using as a compressor cant find a word post corresponding to it though
