Results 1 to 10 of 10
Thread: Water lifter
    Berkshire UK
    thehomeengineer's Tools
    Water lifter
    Hi All
    This is a water lifter filter for my 3” Foden Steam Wagon. I thought I would share the tooling made to form the material along with the drawing so you can see what the product will eventually look like. The main body, is made from two brass pressings and silver soldered together then filed to shape. The webs are also silver solder to the pressings, and then the drilling. Will post more photos of the build as I go. The drawing is actual size of the original water filter, so I have scaled down to ¼ size.
    There is more info on the Foden build on my web site Practical Engineering
    Thank you for viewing
    The Home Engineer
  2. The Following 4 Users Say Thank You to thehomeengineer For This Useful Post:
    Drew1966 (Feb 8, 2018), jjr2001 (Feb 11, 2018), rlm98253 (Feb 8, 2018), Seedtick (Feb 8, 2018)
    Nicely made press mold die set, What is the thickness of your brass sheet/ Did you use common shim stock? If so did you have to anneal it prior to pressing? In the past I've had to make pressing die set for antique carburetor floats out of copper sheets. I found that if I heated the sheets to between 900 to 1200° f then water quenching softened the sheet enough to work it into the complex shapes
    Paul Jones (Feb 9, 2018), PJs (Feb 9, 2018)
    Berkshire UK
    Hi Frank
    The brass is 16 Gauge and I did anneal the brass before pressing. I will have to look out the item and take some better photos.
    The Home Engineer
    Berkshire UK
    Water lifter silver soldered together complete with webs, just needs drilling
  7. The Following 2 Users Say Thank You to thehomeengineer For This Useful Post:
    excellent craftsmanship
    thehomeengineer (Feb 9, 2018)
  10. #6
    May 2014
    Del Mar, California
    Paul Jones's Tools
    I second that. You have excellent craftsmanship.
  11. #7
    Dec 2016
    Ralphxyz's Tools
    post pictures and video of it in operation, please.
    Ralph
  12. #8
    Berkshire UK
    Hi Ralph
    This is part of a model I am building and is used as a filter; the idea is when you need to refill the water tank this item would have been attached to a long hose and tossed in to a river. The other end of the hose attached to an ejector that works in conjunction with steam so the water is drawn into the water storage tank. Sorry no video but I hope this explains what it is for. A very basic filter. Link to how a steam injector works Bluebell Railway Loco Dept News
    Thank you for your interest
  13. #9
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Quote Originally Posted by thehomeengineer View Post
ID:	22056 Click image for larger version.
    Wow it looks like it was cast! Beautiful work! Thanks for showing the mold and the details.
  14. #10
    Thanks thehomeengineer! We've added your Press Mold to our Metalworking category,
