Quote Originally Posted by N00b Machinist View Post
Devil’s Advocate here: I imagine the string portion of a trimmer is to minimize damage to non-weed bystanders, e.g., stakes, mailbox posts, ankles, etc. What you’ve got there is a blunt pole saw. Useful, to be sure, but additional care, I expect, is necessary to avoid tearing up things you don’t want tore or launching stones or cans or other FOD at those nearby, including yourself. Also kickback - that’s going to kick back much harder than a string on a spinner.
In the right hands, a masterful tool. I can imagine myself f**king things up spectacularly in my own.
This is not really a correct assessment of the tool or a string trimmer.
First even the string trimmer is very destructive to all kind of things. The outer edge of a typical string trimmer, 16" diameter @ 7,000 RPM, exceeds 300 MPH. That is high cut through wood fence posts, debark trees, and launch rocks and stones in excess of 300 mph. In regard to kick-back, NO ONE is quick enough to react to a 300MPH force when the string unexpectedly grabs a hold of some immovable object.
Second the alternator rotor is much smaller in diameter, 5" diameter @ 7000 RPM, so only about 100 MPH. That is still very fast, BUT the outer circumference of the edge is much more smooth and not nearly as likely to grab something.
As with any tool, you have to use proper caution.
