Results 1 to 9 of 9
Thread: Welding electrode holder
    Supporting Member Mr.DK DIY's Avatar
    Jan 2019
    Mr.DK DIY's Tools
    Hello,this is my new diy video and new homemade tool for welding ..
    Link :
  2. The Following 4 Users Say Thank You to Mr.DK DIY For This Useful Post:
    Dragonhand (Mar 25, 2019), EnginePaul (Mar 26, 2019), Scotsman Hosie (Mar 26, 2019), Tuomas (Mar 24, 2019)
    Jyväskylä Finland
    Tuomas's Tools
    This is answer to " perfect diy innovative idea" video.
    To be honest.
    Idea is interesting.
    I personally like fast rod changin possibility, changing the rod shouldn't take longer than actual welding task.
    Rod holders have allways been "wobly" that's why welders have allways supported the rod with finger. Specially in vertical welds support is necessary to keep rod steady.
    Rod holder should have possibility to adjust the angle of the rod.
    Also its possible that drill chuck gets stuck at some point, because electrizity that goes trough it "welds" it from the inside, little cap in some place inside it.. "spark" and its stuck.
    That's why rod holders are usually made from copper, it doesn't weld itself.
    I think that actual idea is still interesting, with a little changes it could be "awesome". I actually got an idea from this. Thank you.
  4. The Following 2 Users Say Thank You to Tuomas For This Useful Post:
    Mr.DK DIY (Apr 10, 2019), Scotsman Hosie (Mar 26, 2019)
    When it comes to the electrode holder Benard has done ot better for 40 years and are not much more expensive than just the drill chuck would be
    back when I was pipelining and doing heavy equipment repairs it was Benard or nothing for me, one would last through a 1000 lbs of electrodes or more .
    A simple 1/4 twist to the left opened it then the same to the right closed it Change rod sizes open it more or close it more would accept rods from 1/16" to 1/4" (1.5 to 6mm)
    Also if it didn't have a rod in it you could toss it on the work piece and it wouldn't arc out made of industrial Bakelite with a copper nose shied for heat
    https://www.ebay.com/itm/Bernard-sty...4AAOSw44BYhDmV
  6. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    Mr.DK DIY (Apr 10, 2019), Scotsman Hosie (Mar 26, 2019), Toolmaker51 (Apr 11, 2019)
    Jyväskylä Finland
    Tuomas's Tools
    Esab has twist-lock models too.
    Personally i don't like them very much, because it tends to get loose too easily.
    https://www.ebay.com/itm/200-Amp-Wel...-/322525638189
    I think there should be some way to improve / make a diy version from these models too.
    Mr.dk.diy's model really fixes loosening problem, but i think its possibly that if it touches the workpiece, its jaws welds together. That risk comes when its uninsulated and contains moving parts.
    Thanks Mr.DK DIY! We've added your Welding Electrode Holder to our Welding category,
    as well as to your builder page: Mr.DK DIY's Homemade Tools. Your receipt:
  9. The Following User Says Thank You to DIYer For This Useful Post:
    Mr.DK DIY (Apr 3, 2019)
  10. #6
    ""I think there should be some way to improve / make a diy version from these models too.
    Mr.dk.diy's model really fixes loosening problem, but i think its possibly that if it touches the workpiece, its jaws welds together. That risk comes when its uninsulated and contains moving parts. "" I agree Tuomas, I knew a guy who used his tig torch as his electrode holder hen he needed to do a little stick welding. I thought the collet idea f those would be an excellent way yo make a holder providing they could be made robust enough to handle several hundred amps fo long periods of time and have the ability to go from 1/16" through 1/4" rods without having to change the collets
  11. The Following User Says Thank You to Frank S For This Useful Post:
  12. #7
    Dec 2016
    Ralphxyz's Tools
    I would not like the added weight of the chuck but interesting.
    Ralph
  13. The Following 2 Users Say Thank You to Ralphxyz For This Useful Post:
    HobieDave (Jun 23, 2021), Mr.DK DIY (Apr 10, 2019)
  14. #8
    Supporting Member Dragonhand's Avatar
    Oct 2013
    Dragonhand's Tools
    Liked it so much I built my own! Works a treat, nice flowing weld with no bird **** spatter.Welding electrode holder-img_20190425_150108.jpgWelding electrode holder-img_20190425_150206.jpgWelding electrode holder-img_20190425_150219.jpg
  15. The Following 2 Users Say Thank You to Dragonhand For This Useful Post:
    EnginePaul (Apr 25, 2019), Mr.DK DIY (Apr 26, 2019)
  16. #9
    Jan 2019
    Mr.DK DIY's Tools
    hahahah super Bro,I'm really glad you liked my video and you made your own welding tool, congratulations and just forward
