Results 1 to 6 of 6
Thread: Wire bender for making small chain links for model traction engine steering chains
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    After seeing this thread by kess (supporting member) Wire Bender I had a moment and thought about adapting this style of bender to make chain links for my 1" scale traction engine.
    I decided to use a M8 (5/16") nut and bolt to make the bender as the links are only 6mm x 4mm (1/4" x 5/32") made from 1mm (0.040") copper wire. The following photos show the first few test links and the method used to form links.
    Wire bender for making small chain links for model traction engine steering chains-img_4432-nut-bender.jpg
    Bender made from M8 nut and bolt
    Wire bender for making small chain links for model traction engine steering chains-copper-place.jpg
    Copper cut to length ready for forming
    Wire bender for making small chain links for model traction engine steering chains-img_4434-first-bend.jpg First Bend Wire bender for making small chain links for model traction engine steering chains-img_4435-2nd-bend.jpg Second bend
    Wire bender for making small chain links for model traction engine steering chains-img_4436-closing-link.jpg Closing link with a piece of aluminium
    Wire bender for making small chain links for model traction engine steering chains-img_4437-completed-link.jpg Link removed from bender
    Wire bender for making small chain links for model traction engine steering chains-img_4440-links-tool.jpg Wire bender for making small chain links for model traction engine steering chains-img_4438-test-link.jpg Wire bender for making small chain links for model traction engine steering chains-size-link.jpg First few test links
    The links will be silver soldered at each joint. As there are quite a few links needed I am in the process of designing and making a guillotine to cut the wire to a constant length.
    I hope this thread will be helpful to anyone considering making chain for their model.
    Thank you for taking the time to view
    The Home Engineer
  2. The Following 10 Users Say Thank You to thehomeengineer For This Useful Post:
    baja (Feb 4, 2020), bobs409 (Feb 2, 2020), emu roo (Mar 10, 2025), high-side (Feb 4, 2020), jimfols (Feb 3, 2020), Jon (Feb 2, 2020), kess (Feb 3, 2020), matt_albitz (Feb 3, 2020), rlm98253 (Feb 3, 2020), threesixesinarow (Feb 3, 2020)
    Thanks thehomeengineer! We've added your Small Wire Bender to our Model Making category,
    Dec 2016
    bobs409's Tools
    Neat!
    Supporting Member kess's Avatar
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    Very nice build.
    Well done.
  6. The Following User Says Thank You to kess For This Useful Post:
    thehomeengineer (Feb 4, 2020)
    Berkshire UK
    Chain link bending former
    Please find link to updated post on bending chain links below:
    Re-think on wire bender for making chain links
    Many thanks
    The Home Engineer
    Jul 2019
    That works really well. With your guillotine, if you make the blade shear instead of cut you will get nice square ends on the links.
