Originally Posted by
old kodger
I'm with Nortondommi, I don't know from where you hail, but if it's anywhere where Eucalypts grow, I'd at least triple the size of the ram 4" id minimum.
Clearly, I don't know what pressures the pump is applying, but presuming the "usual" 3000 psi., your ram looks to be about 2" id therefore pi x r squared x 3000 give you around 4.2 tons. not really that much when you consider that the Superaxe log splitter I posted some time back, is around 40 tons. It would also help to stiffen up your rig.
