Results 1 to 10 of 12
Thread: Workshop Tip - How To Shorten Bolts The Easy Way
    Supporting Member Retro Steam Tech's Avatar
    UK
    Retro Steam Tech's Tools
  2. The Following 9 Users Say Thank You to Retro Steam Tech For This Useful Post:
    desbromilow (Oct 21, 2021), lassab999 (Oct 22, 2021), Metallurg33 (Oct 21, 2021), mr mikey (Aug 9, 2025), mule68 (Oct 22, 2021), portstoold (Oct 24, 2021), Stevohdee (Oct 24, 2021), uv8452 (Oct 22, 2021), WmRMeyers (Oct 21, 2021)
    Aug 2012
    Australia
    desbromilow's Tools
    love the hand vice - never seen one with the second handle configuration
    WmRMeyers's Avatar
    Dec 2014
    WmRMeyers's Tools
    I've got one of those with one handle, and one that has a tapered square drive, as to mount in an old carpenter's brace. May have to make a handle for the second one with two knobs on it. Looks very handy!
    Bill
    UK
    The hand vice was made by Millers Falls and although old they do pop up on ebay occasionally. I did a video on it some time ago.
    May 2021
    Vancouver, Washington, USA
    Good tip for shortening screws. I do a similar routine, but with one minor difference. I try to use a higher grade of steel nut than the screw/bolt is made of, and unless there is a specific reason, I try to stick with a high strength carbon steel nut when I shorten stainless steel screws and bolts. as this helps to avoid galling and the male threads always look sharp (pun intended).
    UK
    That's an excellent idea too.
  8. #7
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    I just use a simple hand tool, screw in the fastener in the appropriate hole, squeeze the handles, unscrew the fastener and it's done.
  9. #8
    WmRMeyers's Avatar
    Dec 2014
    WmRMeyers's Tools
    Quote Originally Posted by katy View Post
    That is fine for the limited number of screws it will handle. Not so good if you have anything else. I have three or four of those, from several different makers, and some picked up overseas, and none of them do anything but 4-40, 6-32, 8-32, 10-24 & 10-32. In the past year, and I've not gotten all that much time in my shop in this time, I've also run into 8-36, and 1/4-25, and several smaller metric screws, plus some more microscope screw holes I've not managed to figure out yet. Anyone working on antique American or Japanese sewing machines, for example, will need a bunch more, too. Retro's method will work for anything you have or can make a nut for.
    Bill
  10. #9
    Quote Originally Posted by WmRMeyers View Post
    Bill
    Not to mention that if you had one of those with holes for 1/4 and larger screws you would need a 400 pound gorilla to squeeze the handles for you.
  11. #10
    WmRMeyers's Avatar
    Dec 2014
    WmRMeyers's Tools
    Isn't that why God made hammers?
    Bill
