Results 1 to 7 of 7
Thread: Xtra Tall V-Block
    Dec 2013
    Florida
    rossbotics's Tools
    Xtra Tall V-Block
    On several occasions I have had the need for an Xtra Tall V-Block, in fact one that was around 5” tall would have been nice on several occasions, one that stands vertically that can be used on the surface grinder, drill press, milling machine or on the surface plate for inspection purposes, one that has a right angle base with a nice rigid clamp.
    So I came up with this design, this tool is made to hold round stock up to 1.250” and will hold square stock up to 1.000”, the V-Block is fabricated from three pieces of 4140 Pre-Hardened Steel that has been precision ground all over prior to machining, the three pieces that make up the Xtra Tall V-Block are assembled with six 1/4" dowel pins and secured together with five 1/4" socket head cap screws, then after assembly just the critical surfaces were reground, it is within .0003” in a 5” distance from being perfectly square.
    As always thanks for looking and happy machining.
    Doug
    Comments are always welcome
    Doug
  2. The Following 14 Users Say Thank You to rossbotics For This Useful Post:
    albertq (Feb 12, 2024), asterix (May 20, 2025), Dimitris Polychronis (Dec 25, 2018), emu roo (Apr 21, 2026), Harvey Melvin Richards (May 20, 2025), Home-PC (Dec 10, 2020), Jon (Dec 24, 2018), JRock (Mar 14, 2019), LMMasterMariner (Dec 25, 2018), Metallurg33 (Dec 25, 2018), PJs (Dec 26, 2018), rayh__ (Dec 10, 2020), Seedtick (Dec 24, 2018), threesixesinarow (Dec 24, 2018)
    Jan 2018
    petertha's Tools
    Your tooling & designs are just awesome Doug. Thanks for sharing your beautiful workmanship.
  4. The Following User Says Thank You to petertha For This Useful Post:
    Supporting Member Dimitris Polychronis's Avatar
    Nov 2018
    Athens-Greece
    Dimitris Polychronis's Tools
    Beautiful work and neat design, Doug!! Thanks for sharing!
    Best wishes
    Dimitris
  6. The Following User Says Thank You to Dimitris Polychronis For This Useful Post:
    Thanks rossbotics! We've added your Tall V Block to our Machining category,
    as well as to your builder page: rossbotics's Homemade Tools. Your receipt:
    Dec 2013
    Florida
    rossbotics's Tools
    Thank You petertha
    Your work is very nice as well, happy holidays
    Doug
    Doug
  10. The Following User Says Thank You to rossbotics For This Useful Post:
  11. #6
    Dec 2013
    Florida
    rossbotics's Tools
    Thank You Dimitris
    You do nice work yourself, Happy Holidays
    Doug
    Doug
  12. The Following 2 Users Say Thank You to rossbotics For This Useful Post:
    Dimitris Polychronis (Dec 27, 2018), emu roo (Apr 21, 2026)
  13. #7
    Nov 2018
    Athens-Greece
    Thank you for your kind words, Doug! Happy Holidays, to you too!
    Dimitris
  14. The Following User Says Thank You to Dimitris Polychronis For This Useful Post:
