Results 1 to 10 of 10
Thread: YADH - Yet Another Dividing Head
Hybrid View
    Supporting Member EclecticNeophyte's Avatar
    Apr 2013
    TriCities, WA.
    EclecticNeophyte's Tools
    Unhappy
    Quote Originally Posted by scrdmgl View Post
    Hi Neophyte:
    I read your article about your Dividing Head adaptation and it so happens that I'm planning a similar conversion using a 10" Rotary Table. To that effect, I decided (empirically) to go for a NEMA 23 Stepper Motor 200 steps, 24 V, 3A, 360 oz.in double shaft to allow attachment of a crank wheel at the other end. Since I don't have the capacity to program o assemble a driver and controller, I decided to go for a "stand alone" Programmable Driver/Controller sold by a guy by the name of Bryan Mumford in California.
    It looks like a big calculator and can do all kinds of stuff including jogging and continual rotation plus makes built-in adjustments for "slack" or free play. By the way you obviously run into that situation, were you able to program your controller accordingly?
    Also, what size and specs is your motor? If you wish you can write to me at scrdmgl@gmail.com
    Regards from Toronto, Canada
    Jorge
    Hi Jorge,
    Sorry for the delayed return...
    The stepper motor I used, can be found here:
    http://www.automationtechnologiesinc...at-282-oz-in-2
    As the ad indicates, the torque is 282 oz in. As for the 'brains', I simply used what was laying around my shop at the time. I have a number of the Arduino UNO controllers, as well as a stepper motor (or three?) and the project evolved out of my collection of junk. One word of caution on spinning the stepper motor by hand, while still connected to the motor controller...Larger stepper motors make 'not too bad' permanent magnet alternators. Depending on how fragile the motor controller is, and how fast you spin the stepper it could fry the output of the motor controller. I learned this the hard way! This may not hold true of all of the motor controllers, but the one I was initially using couldn't tolerate the output pulses from the stepper motor.
    Here's a link to a motor controller, similar to the one I ultimately used:
    http://www.ebay.com/itm/CNC-Router-1...gAAMXQBg5RyW0Z
    While I do have ~ 27 years experience as a software developer, I haven't bothered to modify the Arduino code to handle backlash, or slop in the gearing. Some day perhaps...
    Hope this helps. I'll be looking forward to reading about your rotary table project!
    -EN
  2. The Following User Says Thank You to EclecticNeophyte For This Useful Post:
    emu roo (Sep 1, 2025)
    Supporting Member scrdmgl's Avatar
    Oct 2013
    Toronto, Ontario, Canada
    scrdmgl's Tools
    Thank you Ken for the info. I'm surprised that your 282 oz.in. motor has enough power to move your monster indexing device.
    Therefore, the one that I selected with 360 oz.in., should be more than enough to move my table. Given my blissful ignorance in these electronic matters, I decided to go big to avoid trouble and the price difference is minuscule. Regarding construction, the idea is to gather all the components first and then to start fabrication and assembly. What I could do to lower cost, is to buy a driver such as the one mentioned in your response, and then find someone to write the program for me to run the contraption because the "All in one" controller/driver that I intended to buy is expensive. Despite my lack of knowledge of electronics, I would never run the motor with the crank and the unit being connected. The purpose of the crank is have the ability to move the table manually if needed as an option. Additionally, I figure that to avoid "backlash" or free play, one simple option is to run the unit in one direction only or take up the slack in a manner similar to what we use with machine tools if reversal of rotation is required. I wonder how the guy that makes the controller that I mentioned, accomplishes the feat?
    By the way, do you have or built, a tail stock to complement your indexer? I'll be looking into that too.
    Jorge
  4. The Following User Says Thank You to scrdmgl For This Useful Post:
    Apr 2013
    TriCities, WA.
    Jorge
    I think it largely depends on how you intend to use it. If you plan to rotate a part while machining it, then the size of the part, depth of cut and so on, would dictate the size of stepper motor needed. Since (to date) I've only needed to turn a part, lock it in position, mill, then turn, repeat, etc; my stepper motor has more than adequate power (perhaps more than I need?). My primary goal was to cut spur gears, consequently my dividing head setup is pretty simple.
    I have not yet built a tail-stock for it... It's good that you asked however, as I was just thinking of that the other day. So you have reminded me of yet another project!
    Best regards,
    -EN
  6. The Following User Says Thank You to EclecticNeophyte For This Useful Post:
    Oct 2013
    scrdmgl's Tools
    Glad to be an inspiration to you because in fact, life is a "Merry-go-round" and we inspire each other. Take me for instance, I'm planning to build fixtures, jigs and other contraptions to help me work faster and easier in the shop. I'm planning to move into a new shop sometime this coming spring. I have a long list of projects to build and I take inspiration from commercial models or samples devised and conceived by other people to which, in an irrepressible manner ,I modify or adapt to my own needs or to make them better or easier to build. You're probably aware of a comment by one of the great minds of humanity (Isaac Newton) who once said "I was able to see farther because I was standing on the shoulders of giants who came before me", how true.
    Let me know if you wish to have a copy of it. They said that curiosity killed the cat but I add that ambition too; therefore, I'm on a road to perdition because one of the features that I try to include in my "creations" is to be able to use them in the lathe as well as the mill or even a drill press (I figure that I'm doomed by now) hahahaha. I'm gonna have going very soon, a "Mechanical Filing Machine" to finish precise surfaces easier that by hand filing.
  8. The Following 2 Users Say Thank You to scrdmgl For This Useful Post:
    emu roo (Sep 1, 2025), Paul Jones (Mar 31, 2016)
    Apr 2013
    TriCities, WA.
    Jorge
    I have not yet built a tail-stock for it... It's good that you asked however, as I was just thinking of that just the other day. So you have reminded me of yet another project!
    One final note... Because my lathe chucks thread on, I can't easily reverse rotation during a cut, or cut in such a way as to force the chuck to 'unwind'. So compensating (in software/firmware) for backlash or gear play hasn't been a big concern.
    Best regards,
    -EN
  10. The Following User Says Thank You to EclecticNeophyte For This Useful Post:
