Remove advertisements
Thread: Drill press chuck extension
    Soikkeli Tuomas's Avatar
    Jyväskylä Finland
    Tuomas's Tools
    Hi
    Chuck in my drill press doesn't hold little drills.
    Its for 4mm-16mm. So far i have used dremel workstation drill press with smaller holes.
    I wanted to use dremel diamond cut off wheel with it.
    Also dremel workstation ain't very accurate to drill metal, so this fix that issue too.
    I had smaller chuck, it was with 3/8" thread, but i had no suitable threaded rod, so i re-threaded it with M12
    Then used M12 threaded rod to connect smaller chuck to the drill.
    Now i can use drills between 0-16mm. Its quick to change and allows me to use my drill with dremel bits too.
    Easy to adjust lenght if needed.
    Wanted to use diamond cut off wheel to re-use broken glass jar.
  2. The Following 3 Users Say Thank You to Tuomas For This Useful Post:
    Paul Jones (09-26-2017), rlm98253 (09-24-2017), Seedtick (09-24-2017)
    Content Editor DIYer's Avatar
    Thanks Tuomas! We've added your Drill Press Chuck Extension to our Drilling and Drill Presses category,
    Carpenter & blacksmith Philip Davies's Avatar
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    My sole metal machining project to date has been to attempt a device that fits the spigot of my shopsmith to hold a larger chuck, so that I can use 16mm shank drills, but unfortunately this was a failure, because the hole was not truly centred. Well, no harm done! I would like to fit the chuck somehow.
    Post your reply!
