Homemade tools made with Harbor Freight tools
Here's a rundown on some Harbor Freight tools we have listed in the encyclopedia. To get this list, I simply searched the database for "Harbor Freight" and "HF".
Some misc Harbor Freight tips are at the bottom. Additional tools? Tips? Advice? Post in this thread. :)
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="/upgraded-hf-bead-roller"><img src="/uploads/13298/upgraded-hf-bead-roller.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/upgraded-hf-bead-roller">Upgraded HF Bead Roller</a>
<span> by <a href="/builder/ak%27s-r-us">ak's-r-us</a></span>
</div>
<div class="tags">tags: <a href="/tag/bead-roller">bead roller</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/modified-hf-drill-press"><img src="/uploads/14244/modified-hf-drill-press.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/modified-hf-drill-press">Modified HF Drill Press</a>
<span> by <a href="/builder/dabeldesign">dabeldesign</a></span>
</div>
<div class="tags">tags: <a href="/tag/drill-press">drill press</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/motorized-hf-tubing-roller"><img src="/uploads/4244/motorized-hf-tubing-roller.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/motorized-hf-tubing-roller">Motorized HF Tubing Roller</a>
<span> by <a href="/builder/Bonehead">Bonehead</a></span>
</div>
<div class="tags">tags: <a href="/tag/tube-bender">tube bender</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/square-tube-bending-die-for-hf-pipe-bender"><img src="/uploads/30/square-tube-bending-die-for-hf-pipe-bender.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/square-tube-bending-die-for-hf-pipe-bender">Square Tube Bending Die for HF Pipe Bender</a>
<span> by <a href="/builder/cboy">cboy</a></span>
</div>
<div class="tags">tags: <a href="/tag/pipe-bender">pipe bender</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/powered-hf-bead-roller"><img src="/uploads/306/powered-hf-bead-roller.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/powered-hf-bead-roller">Powered HF Bead Roller</a>
<span> by <a href="/builder/Dammit">Dammit</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/modified-hf-bead-roller"><img src="/uploads/288/modified-hf-bead-roller.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/modified-hf-bead-roller">Modified HF Bead Roller</a>
<span> by <a href="/builder/mosimpson">mosimpson</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/harbor-freight-bead-roller-modifications"><img src="/uploads/252/harbor-freight-bead-roller-modifications.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/harbor-freight-bead-roller-modifications">Harbor Freight Bead Roller Modifications</a>
<span> by <a href="/builder/Jim+Stabe">Jim Stabe</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/hf-bead-roller-stand"><img src="/uploads/2791/hf-bead-roller-stand.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/hf-bead-roller-stand">HF Bead Roller Stand</a>
<span> by <a href="/builder/NealinCA">NealinCA</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/tig-electrode-sharpener"><img src="/uploads/15328/tig-electrode-sharpener.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/tig-electrode-sharpener">TIG Electrode Sharpener</a>
<span> by <a href="/builder/courtjester">courtjester</a></span>
</div>
<div class="tags">tags: <a href="/tag/grinding">grinding</a>, <a href="/tag/welder">welder</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/scratch-built-tubing-roller"><img src="/uploads/4241/scratch-built-tubing-roller.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/scratch-built-tubing-roller">Scratch-Built Tubing Roller</a>
<span> by <a href="/builder/Brian1">Brian1</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/hydraulic-tubing-bender-conversion"><img src="/uploads/4256/hydraulic-tubing-bender-conversion.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/hydraulic-tubing-bender-conversion">Hydraulic Tubing Bender Conversion</a>
<span> by <a href="/builder/cweed">cweed</a></span>
</div>
<div class="tags">tags: <a href="/tag/bender">bender</a>, <a href="/tag/hydraulic">hydraulic</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/inexpensive-router-lift"><img src="/uploads/6613/inexpensive-router-lift.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/inexpensive-router-lift">Inexpensive Router Lift</a>
<span> by <a href="/builder/Vestus">Vestus</a></span>
</div>
<div class="tags">tags: <a href="/tag/lifting">lifting</a>, <a href="/tag/router">router</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/hf-mill-z-axis-upgrade"><img src="/uploads/8681/hf-mill-z-axis-upgrade.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/hf-mill-z-axis-upgrade">HF Mill Z-Axis Upgrade</a>
<span> by <a href="/builder/FLSTEAM">FLSTEAM</a></span>
</div>
<div class="tags">tags: <a href="/tag/cnc">CNC</a>, <a href="/tag/mill">mill</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/hf-motor-reversing-switch-wiring"><img src="/uploads/3911/hf-motor-reversing-switch-wiring.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/hf-motor-reversing-switch-wiring">HF Motor Reversing Switch Wiring</a>
<span> by <a href="/builder/wlw_19958">wlw_19958</a></span>
</div>
<div class="tags">tags: <a href="/tag/electrical">electrical</a>, <a href="/tag/motor">motor</a>, <a href="/tag/rewiring">rewiring</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/jib-crane-for-mill"><img src="/uploads/813/jib-crane-for-mill.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/jib-crane-for-mill">Jib Crane for Mill</a>
<span> by <a href="/builder/platypus20">platypus20</a></span>
</div>
<div class="tags">tags: <a href="/tag/jib-crane">jib crane</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/lifting-table"><img src="/uploads/5597/lifting-table.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/lifting-table">Lifting Table</a>
<span> by <a href="/builder/seal+killer">seal killer</a></span>
</div>
<div class="tags">tags: <a href="/tag/table">table</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/portable-bandsaw-vertical-bracket"><img src="/uploads/15960/portable-bandsaw-vertical-bracket.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/portable-bandsaw-vertical-bracket">Portable Bandsaw Vertical Bracket</a>
<span> by <a href="/builder/Machine_Punk">Machine_Punk</a></span>
</div>
<div class="tags">tags: <a href="/tag/bandsaw">bandsaw</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/english-wheel-5"><img src="/uploads/16008/english-wheel-5.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/english-wheel-5">English Wheel</a>
<span> by <a href="/builder/Howard+Connelly+Design">Howard Connelly Design</a></span>
</div>
<div class="tags">tags: <a href="/tag/light">light</a>, <a href="/tag/english-wheel">English wheel</a>, <a href="/tag/dolly-stand">dolly stand</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/transmission-jack"><img src="/uploads/24788/transmission-jack.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/transmission-jack">Transmission Jack</a>
<span> by <a href="/builder/glfredrick">glfredrick</a></span>
</div>
<div class="tags">tags: <a href="/tag/transmission">transmission</a>, <a href="/tag/jack">jack</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/vertical-bender-stand"><img src="/uploads/27960/vertical-bender-stand.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/vertical-bender-stand">Vertical Bender Stand</a>
<span> by <a href="/builder/Hiapo">Hiapo</a></span>
</div>
<div class="tags">tags: <a href="/tag/tube-bender">tube bender</a>, <a href="/tag/hydraulic">hydraulic</a>, <a href="/tag/ram">ram</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/extended-ratchet-handle"><img src="/uploads/43844/extended-ratchet-handle.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/extended-ratchet-handle">Extended Ratchet Handle</a>
<span> by <a href="/builder/nissan_crawler">nissan_crawler</a></span>
</div>
<div class="tags">tags: <a href="/tag/ratchet">ratchet</a>, <a href="/tag/hand-tools">hand tools</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/pinion-gear-puller-3"><img src="/uploads/44360/pinion-gear-puller-3.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/pinion-gear-puller-3">Pinion Gear Puller</a>
<span> by <a href="/builder/Witha+C">Witha C</a></span>
</div>
<div class="tags">tags: <a href="/tag/puller">puller</a>, <a href="/tag/motorcycle">motorcycle</a>, <a href="/tag/crankshaft">crankshaft</a>, <a href="/tag/pinion">pinion</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/drain-fitting"><img src="/uploads/49560/drain-fitting.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/drain-fitting">Drain Fitting</a>
<span> by <a href="/builder/Camfx">Camfx</a></span>
</div>
<div class="tags">tags: <a href="/tag/drain">drain</a>, <a href="/tag/fitting">fitting</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/stepped-fingers-for-sheetmetal-brake"><img src="/uploads/52444/stepped-fingers-for-sheetmetal-brake.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/stepped-fingers-for-sheetmetal-brake">Stepped Fingers for Sheetmetal Brake</a>
<span> by <a href="/builder/astroracer_2">astroracer</a></span>
</div>
<div class="tags">tags: <a href="/tag/sheetmetal">sheetmetal</a>, <a href="/tag/brake">brake</a>, <a href="/tag/flange">flange</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/tube-bender-12"><img src="/uploads/53488/tube-bender-12.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/tube-bender-12">Tube Bender</a>
<span> by <a href="/builder/rigger77">rigger77</a></span>
</div>
<div class="tags">tags: <a href="/tag/tube-bender">tube bender</a>, <a href="/tag/welding">welding</a>, <a href="/tag/pneumatic">pneumatic</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/nut-starter-2"><img src="/uploads/55352/nut-starter-2.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/nut-starter-2">Nut Starter</a>
<span> by <a href="/builder/James+Waldby">James Waldby</a></span>
</div>
<div class="tags">tags: <a href="/tag/lathe">lathe</a>, <a href="/tag/clamp">clamp</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/oval-tray-jig"><img src="/uploads/55692/oval-tray-jig.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/oval-tray-jig">Oval Tray Jig</a>
<span> by <a href="/builder/shipwright">shipwright</a></span>
</div>
<div class="tags">tags: <a href="/tag/jig">jig</a>, <a href="/tag/router">router</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/universal-pulley-holder"><img src="/uploads/65732/universal-pulley-holder.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/universal-pulley-holder">Universal Pulley Holder</a>
<span> by <a href="/builder/blknblu">blknblu</a></span>
</div>
<div class="tags">tags: <a href="/tag/pulley">pulley</a>, <a href="/tag/crankshaft">crankshaft</a>, <a href="/tag/holder">holder</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/brake-drum-puller-2"><img src="/uploads/70196/brake-drum-puller-2.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/brake-drum-puller-2">Brake Drum Puller</a>
<span> by <a href="/builder/cell">cell</a></span>
</div>
<div class="tags">tags: <a href="/tag/puller">puller</a>, <a href="/tag/brake-drums">brake drums</a>, <a href="/tag/welding">welding</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/drive-adaptor-for-pipe-threader"><img src="/uploads/71060/drive-adaptor-for-pipe-threader.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/drive-adaptor-for-pipe-threader">Drive Adaptor for Pipe Threader</a>
</div>
<div class="tags">tags: <a href="/tag/pipe">pipe</a>, <a href="/tag/welding">welding</a>, <a href="/tag/threading">threading</a>, <a href="/tag/adaptor">adaptor</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/minibike-lift"><img src="/uploads/73168/minibike-lift.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/minibike-lift">Minibike Lift</a>
<span> by <a href="/builder/byron+ness">byron ness</a></span>
</div>
<div class="tags">tags: <a href="/tag/motorcycle">motorcycle</a>, <a href="/tag/lifting">lifting</a>, <a href="/tag/workstand">workstand</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/solar-powered-auxiliary-power-system"><img src="/uploads/78716/solar-powered-auxiliary-power-system.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/solar-powered-auxiliary-power-system">Solar-Powered Auxiliary Power System</a>
<span> by <a href="/builder/Feedthelibertytree">Feedthelibertytree</a></span>
</div>
<div class="tags">tags: <a href="/tag/toolbox">toolbox</a>, <a href="/tag/fan">fan</a>, <a href="/tag/battery">battery</a>, <a href="/tag/power-supply">power supply</a>, <a href="/tag/electronics">electronics</a>, <a href="/tag/controller">controller</a>, <a href="/tag/inverter">inverter</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/rim-roller-3"><img src="/uploads/79248/rim-roller-3.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/rim-roller-3">Rim Roller</a>
</div>
<div class="tags">tags: <a href="/tag/workbench">workbench</a>, <a href="/tag/roller">roller</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/angle-grinder-table-saw"><img src="/uploads/82504/angle-grinder-table-saw.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/angle-grinder-table-saw">Angle Grinder Table Saw</a>
<span> by <a href="/builder/Rick+Sparber">Rick Sparber</a></span>
</div>
<div class="tags">tags: <a href="/tag/angle-grinder">angle grinder</a>, <a href="/tag/table-saw">table saw</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/english-wheel-13"><img src="/uploads/100056/english-wheel-13.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/english-wheel-13">English Wheel</a>
<span> by <a href="/builder/captainleeward">Captainleeward</a></span>
</div>
<div class="tags">tags: <a href="/tag/welding">welding</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/multifunction-divider-and-compass"><img src="/uploads/101400/multifunction-divider-and-compass.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/multifunction-divider-and-compass">Multifunction Divider and Compass</a>
<span> by <a href="/builder/CedarSlayer">CedarSlayer</a></span>
</div>
<div class="tags">tags: <a href="/tag/grinding">grinding</a>, <a href="/tag/divider">divider</a>, <a href="/tag/compass">compass</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/reverse-tumbler-modification"><img src="/uploads/102853/reverse-tumbler-modification.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/reverse-tumbler-modification">Reverse Tumbler Modification</a>
</div>
<div class="tags">tags: <a href="/tag/lathe">lathe</a>, <a href="/tag/modification">modification</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/bandsaw-laser-guide"><img src="/uploads/112258/bandsaw-laser-guide.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/bandsaw-laser-guide">Bandsaw Laser Guide</a>
<span> by <a href="/builder/harborfreight8x12">harborfreight8x12</a></span>
</div>
<div class="tags">tags: <a href="/tag/bandsaw">bandsaw</a>, <a href="/tag/laser">laser</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/round-tubing-layout-jig"><img src="/uploads/120228/round-tubing-layout-jig.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/round-tubing-layout-jig">Round Tubing Layout Jig</a>
</div>
<div class="tags">tags: <a href="/tag/tubing">tubing</a>, <a href="/tag/jig">jig</a>, <a href="/tag/layout">layout</a>, <a href="/tag/casters">caster(s)</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/mini-lathe-cross-slide-dro"><img src="/uploads/120976/mini-lathe-cross-slide-dro.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/mini-lathe-cross-slide-dro">Mini Lathe Cross Slide DRO</a>
<span> by <a href="/builder/DaveInPA">DaveInPA</a></span>
</div>
<div class="tags">tags: <a href="/tag/lathe">lathe</a>, <a href="/tag/dro">DRO</a>, <a href="/tag/cross-slide">cross slide</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/t-square-fence-and-table-extension"><img src="/uploads/122415/t-square-fence-and-table-extension.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/t-square-fence-and-table-extension">T-Square Fence and Table Extension</a>
<span> by <a href="/builder/mr95gst">mr95gst</a></span>
</div>
<div class="tags">tags: <a href="/tag/square">square</a>, <a href="/tag/table-saw">table saw</a>, <a href="/tag/fence">fence</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/modified-harbor-freight-bead-roller"><img src="/uploads/279/modified-harbor-freight-bead-roller.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/modified-harbor-freight-bead-roller">Modified Harbor Freight Bead Roller</a>
<span> by <a href="/builder/themodernartist">themodernartist</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
</div>
</div>
<div class="title">
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/modifications-to-a-harbor-freight-english-wheel"><img src="/uploads/1500/modifications-to-a-harbor-freight-english-wheel.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/modifications-to-a-harbor-freight-english-wheel">Modifications to a Harbor Freight English Wheel</a>
<span> by <a href="/builder/James+P.+Riser">James P. Riser</a></span>
</div>
<div class="tags">tags: <a href="/tag/english-wheel">English wheel</a></div>
</div>
</div>
<div class="bimg">
<div>
</div>
</div>
<div class="title">
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/transmission-adaptor-for-cherry-picker"><img src="/uploads/831/transmission-adaptor-for-cherry-picker.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/transmission-adaptor-for-cherry-picker">Transmission Adaptor for Cherry Picker</a>
<span> by <a href="/builder/convx4">convx4</a></span>
</div>
<div class="tags">tags: <a href="/tag/transmission">transmission</a>, <a href="/tag/floor-jack">floor jack</a>, <a href="/tag/crane">crane</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/power-added-ring-roller"><img src="/uploads/873/power-added-ring-roller.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/power-added-ring-roller">Power-Added Ring Roller</a>
<span> by <a href="/builder/badshifter">badshifter</a></span>
</div>
<div class="tags">tags: <a href="/tag/ring-roller">ring roller</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/cherry-picker-shop-press"><img src="/uploads/912/cherry-picker-shop-press.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/cherry-picker-shop-press">Cherry Picker Shop Press</a>
<span> by <a href="/builder/mixedupamx">mixedupamx</a></span>
</div>
<div class="tags">tags: <a href="/tag/press">press</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/bead-roller-with-hand-wheel"><img src="/uploads/939/bead-roller-with-hand-wheel.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/bead-roller-with-hand-wheel">Bead Roller with Hand Wheel</a>
<span> by <a href="/builder/Glenn_2">Glenn</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/adjustable-body-dolly"><img src="/uploads/966/adjustable-body-dolly.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/adjustable-body-dolly">Adjustable Body Dolly</a>
<span> by <a href="/builder/4t64rd">4t64rd</a></span>
</div>
<div class="tags">tags: <a href="/tag/autobody">autobody</a>, <a href="/tag/dolly">dolly</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/powered-bead-roller"><img src="/uploads/1008/powered-bead-roller.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/powered-bead-roller">Powered Bead Roller</a>
<span> by <a href="/builder/fbama73">fbama73</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/freestanding-visqueen-paint-booth"><img src="/uploads/1041/freestanding-visqueen-paint-booth.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/freestanding-visqueen-paint-booth">Freestanding Visqueen Paint Booth</a>
<span> by <a href="/builder/Christopher_2">Christopher</a></span>
</div>
<div class="tags">tags: <a href="/tag/painting">painting</a>, <a href="/tag/paint-booth">paint booth</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/hydraulic-tubing-bender"><img src="/uploads/702/hydraulic-tubing-bender.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/hydraulic-tubing-bender">Hydraulic Tubing Bender</a>
<span> by <a href="/builder/Twisted+Minis_2">Twisted Minis</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/accurized-craftsman-drill-press"><img src="/uploads/636/accurized-craftsman-drill-press.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/accurized-craftsman-drill-press">Accurized Craftsman Drill Press</a>
</div>
</div>
</div>
<div class="bimg">
<div>
</div>
</div>
<div class="title">
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/shop-crane"><img src="/uploads/294/shop-crane.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/shop-crane">Shop Crane</a>
</div>
<div class="tags">tags: <a href="/tag/crane">crane</a></div>
</div>
</div>
<div class="bimg">
<div>
</div>
</div>
<div class="title">
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/self-lifting-rotisserie"><img src="/uploads/1065/self-lifting-rotisserie.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/self-lifting-rotisserie">Self-Lifting Rotisserie</a>
</div>
<div class="tags">tags: <a href="/tag/rotisserie">rotisserie</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/bolt-cutter-rivet-crusher"><img src="/uploads/2713/bolt-cutter-rivet-crusher.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/bolt-cutter-rivet-crusher">Bolt Cutter Rivet Crusher</a>
<span> by <a href="/builder/CatCow">CatCow</a></span>
</div>
<div class="tags">tags: <a href="/tag/rivet">rivet</a>, <a href="/tag/hand-tools">hand tools</a>, <a href="/tag/gunsmithing">gunsmithing</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/bead-roller-modifications"><img src="/uploads/1428/bead-roller-modifications.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/bead-roller-modifications">Bead Roller Modifications</a>
<span> by <a href="/builder/Various+MSA+Members">Various MSA Members</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/low-budget-motorcycle-lift"><img src="/uploads/2346/low-budget-motorcycle-lift.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/low-budget-motorcycle-lift">Low-Budget Motorcycle Lift</a>
<span> by <a href="/builder/Bill+Dudley">Bill Dudley</a></span>
</div>
<div class="tags">tags: <a href="/tag/motorcycle">motorcycle</a>, <a href="/tag/jack">jack</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/deburring-tumbler"><img src="/uploads/3459/deburring-tumbler.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/deburring-tumbler">Deburring Tumbler</a>
<span> by <a href="/builder/Mark_2">Mark</a></span>
</div>
<div class="tags">tags: <a href="/tag/deburring">deburring</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/belt-grinderdeburrer"><img src="/uploads/3354/belt-grinderdeburrer.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/belt-grinderdeburrer">Belt Grinder/Deburrer</a>
<span> by <a href="/builder/lbhsbz">lbhsbz</a></span>
</div>
<div class="tags">tags: <a href="/tag/belt-grinder">belt grinder</a>, <a href="/tag/deburring">deburring</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/airhydraulic-tubing-bender"><img src="/uploads/3612/airhydraulic-tubing-bender.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/airhydraulic-tubing-bender">Air/Hydraulic Tubing Bender</a>
<span> by <a href="/builder/medwards">medwards</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/pocket-knife-sharpener"><img src="/uploads/15288/pocket-knife-sharpener.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/pocket-knife-sharpener">Pocket Knife Sharpener</a>
<span> by <a href="/builder/jvander68">jvander68</a></span>
</div>
<div class="tags">tags: <a href="/tag/grinder">grinder</a>, <a href="/tag/knife">knife</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/tube-notching-setup"><img src="/uploads/4514/tube-notching-setup.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/tube-notching-setup">Tube Notching Setup</a>
<span> by <a href="/builder/Hollywood">Hollywood</a></span>
</div>
<div class="tags">tags: <a href="/tag/jig">jig</a>, <a href="/tag/notcher">notcher</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/air-cylinder-propane-forge"><img src="/uploads/5012/air-cylinder-propane-forge.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/air-cylinder-propane-forge">Air Cylinder Propane Forge</a>
<span> by <a href="/builder/Rob+Garner">Rob Garner</a></span>
</div>
<div class="tags">tags: <a href="/tag/forge">forge</a>, <a href="/tag/propane">propane</a></div>
</div>
</div>
<div class="bimg">
<div>
</div>
</div>
<div class="title">
</div>
</div>
</div>
<div class="bimg">
<div>
</div>
</div>
<div class="title">
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/machete-wrench"><img src="/uploads/15556/machete-wrench.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/machete-wrench">Machete Wrench</a>
<span> by <a href="/builder/EV+Builder">EV Builder</a></span>
</div>
<div class="tags">tags: <a href="/tag/wrench">wrench</a>, <a href="/tag/machete">machete</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/end-mill-sharpener-2"><img src="/uploads/14996/end-mill-sharpener-2.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/end-mill-sharpener-2">End Mill Sharpener</a>
<span> by <a href="/builder/DICKEYBIRD_3">DICKEYBIRD</a></span>
</div>
<div class="tags">tags: <a href="/tag/sharpening">sharpening</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/dust-collector"><img src="/uploads/12017/dust-collector.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/dust-collector">Dust Collector</a>
<span> by <a href="/builder/Dan+Sherman">Dan Sherman</a></span>
</div>
<div class="tags">tags: <a href="/tag/dust-collection">dust collection</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/cyclonic-separator-mod-for-dust-collector"><img src="/uploads/12121/cyclonic-separator-mod-for-dust-collector.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/cyclonic-separator-mod-for-dust-collector">Cyclonic Separator Mod for Dust Collector</a>
<span> by <a href="/builder/JERRY54">JERRY54</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/bandsaw-fence-4"><img src="/uploads/21912/bandsaw-fence-4.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/bandsaw-fence-4">Bandsaw Fence</a>
<span> by <a href="/builder/Jei%27son">Jei'son</a></span>
</div>
<div class="tags">tags: <a href="/tag/bandsaw">bandsaw</a>, <a href="/tag/clamp">clamp</a>, <a href="/tag/fence">fence</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/flat-six-engine-stand"><img src="/uploads/25528/flat-six-engine-stand.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/flat-six-engine-stand">Flat Six Engine Stand</a>
<span> by <a href="/builder/Cupcar">Cupcar</a></span>
</div>
<div class="tags">tags: <a href="/tag/engine">engine</a>, <a href="/tag/stand">stand</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/hardtop-hoist-4"><img src="/uploads/28736/hardtop-hoist-4.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/hardtop-hoist-4">Hardtop Hoist</a>
<span> by <a href="/builder/xxxflhrci">xxxflhrci</a></span>
</div>
<div class="tags">tags: <a href="/tag/hoist">hoist</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/hardtop-gantry"><img src="/uploads/28760/hardtop-gantry.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/hardtop-gantry">Hardtop Gantry</a>
<span> by <a href="/builder/grymsr">grymsr</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/car-rotisserie-4"><img src="/uploads/30948/car-rotisserie-4.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/car-rotisserie-4">Car Rotisserie</a>
<span> by <a href="/builder/HelmetHead">HelmetHead</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/engine-dolly-6"><img src="/uploads/39892/engine-dolly-6.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/engine-dolly-6">Engine Dolly</a>
<span> by <a href="/builder/wildcat85">wildcat85</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/fold-down-workbench-3"><img src="/uploads/47004/fold-down-workbench-3.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/fold-down-workbench-3">Fold-Down Workbench</a>
<span> by <a href="/builder/redryder">redryder</a></span>
</div>
<div class="tags">tags: <a href="/tag/workbench">workbench</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/disc-sander-11"><img src="/uploads/60496/disc-sander-11.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/disc-sander-11">Disc Sander</a>
</div>
<div class="tags">tags: <a href="/tag/disc-sander">disc sander</a>, <a href="/tag/motor">motor</a>, <a href="/tag/switch">switch</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/spot-welder-tips"><img src="/uploads/64516/spot-welder-tips.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/spot-welder-tips">Spot Welder Tips</a>
<span> by <a href="/builder/BradMartinson">BradMartinson</a></span>
</div>
<div class="tags">tags: <a href="/tag/spot-welder">spot welder</a>, <a href="/tag/lathe">lathe</a>, <a href="/tag/tips">tips</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/chamfer-plane"><img src="/uploads/65424/chamfer-plane.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/chamfer-plane">Chamfer Plane</a>
<span> by <a href="/builder/rhoddity">rhoddity</a></span>
</div>
<div class="tags">tags: <a href="/tag/chamfer">chamfer</a>, <a href="/tag/plane">plane</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/truck-crane"><img src="/uploads/82996/truck-crane.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/truck-crane">Truck Crane</a>
<span> by <a href="/builder/coyotencuttin">coyotencuttin</a></span>
</div>
<div class="tags">tags: <a href="/tag/truck">truck</a>, <a href="/tag/crane">crane</a>, <a href="/tag/welding">welding</a>, <a href="/tag/winch">winch</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/generator-10"><img src="/uploads/83060/generator-10.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/generator-10">Generator</a>
<span> by <a href="/builder/Tim_3">Tim</a></span>
</div>
<div class="tags">tags: <a href="/tag/engine">engine</a>, <a href="/tag/generator">generator</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/trailer-mounted-winch"><img src="/uploads/113638/trailer-mounted-winch.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/trailer-mounted-winch">Trailer-Mounted Winch</a>
<span> by <a href="/builder/jniolon">jniolon</a></span>
</div>
<div class="tags">tags: <a href="/tag/trailer">trailer</a>, <a href="/tag/winch">winch</a></div>
</div>
</div>
</div>
Some keys to getting value from Harbor Freight:
-Accept that HF will never be the equivalent of a "real" tool supplier.
-Work the sales and discounts and coupons and tricks. An inexpensive tool can turn into a ridiculously inexpensive tool.
-Understand the difference between inexpensive and cheap. Sometimes the difference is important, sometimes it simply doesn't exist.
-Be cautious with consumables. Blades, bits, etc. These need an extra skeptical eye. You don't "save" anything if one breaks at a critical moment, and they will usually break when they are storing the greatest amount of energy.
-You usually get what you pay for. The upside is that this means that you don't get a 50-cent driver for $8, like is sometimes the case at big box stores. That 50-cent driver is usually priced accurately, for better or for worse.
-Get your spelling lessons elsewhere. It takes a special kind of company to stamp a misspelled version of "Pittsburgh" into a tool. :)
-It might be advantageous for you to buy multiple instances of a specific tool, toss them around, lose some, break some, etc. For specific tools, in specific situations, you could come ahead like this, and avoid the stress of monitoring a fancy tool in a certain environment.
-HF might be best as a tool "platform". If you can buy basic tools there, and mod them, you'll likely extract the maximum value from their offerings.
