Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Quick bevel tool
    Jun 2018
    Stevohdee's Tools
    Quick bevel tool
    Hi fellow makers,
    Made this little number a while back, got sick of winding back the compound to adjust angle to do simple taper or bevel. When I road tested it I had real trepidation that this is going to end badly but works well. Even finally after designing a better compound angle system still use it often for tight or small tasks and no winding required.
    cheers stevoh
  2. The Following 18 Users Say Thank You to Stevohdee For This Useful Post:
    Alan Purdy (Feb 2, 2019), ChasT (Jun 7, 2022), high-side (Sep 2, 2020), HobieDave (Mar 20, 2020), Home-PC (Sep 4, 2020), HUMARIA (Sep 3, 2020), jackhoying (Jun 18, 2018), NortonDommi (Jun 19, 2018), Okapi (Aug 3, 2018), old_toolmaker (Jun 19, 2018), Paul Jones (Jun 18, 2018), PJs (Jun 18, 2018), rossbotics (Jun 18, 2018), Seedtick (Jun 18, 2018), swk (Jun 8, 2022), threesixesinarow (Jul 21, 2018), Tonyg (Nov 24, 2018), Toolmaker51 (Jun 18, 2018)
    Dec 2013
    Florida
    rossbotics's Tools
    Very Good
    Doug
    Comments are always welcome
    Doug
    Jun 2018
    Stevohdee's Tools
    Thanks doug, im slowly posting stuff I've made. Had a unimat 3 for 20 years and decided wanted to do bigger projects, hence the struggle with the chinese mini lathe shortfalls. Bought in mid 2015, then came across second hand but still new mini mill in jan 2017 for good price. Still learning but enjoying challenges. Cheers
    Dec 2016
    Ralphxyz's Tools
    What is the purpose of the slide? I can see that when threading but not tapers/bevels.
    Very nicely made.
    Ralph
    Oct 2012
    Stevoh
    Very nice and great idea. Threading would out very well. and any small cut at any angle you set it at, the only draw back would be the depth of cut.
    Nice work
    Nelson
    Jun 2018
    Stevohdee's Tools
    Thanks ralph, the whole idea is to make a cut on an angle just by sliding the cutter into the material simply by pushing then pulling the handle rather than using the compound slide, hope this makes it clearer,
    Regards stevoh
  8. The Following User Says Thank You to Stevohdee For This Useful Post:
    volodar (Jun 20, 2018)
  9. #7
    Jun 2018
    Stevohdee's Tools
    Thanks nelson, travel on slide is 13mm, depth of cut or the amount of material removed on a pass depends on type of material. Brass & aluminium cuts effectively with no chatter, I've sometimes cut up to 1mm in one pass. With steel I tend to be less aggressive.
    Regards stevoh
  10. #8
    Quote Originally Posted by Stevohdee View Post
    Hi fellow makers,...Made this little number a while back, got sick of winding back the compound to adjust angle to do simple taper or bevel. When I road tested it I had real trepidation that this is going to end badly but works well. Even finally after designing a better compound angle system still use it often for tight or small tasks and no winding required.
    cheers stevoh
Name:	DSC_2124 (Large).jpg
    Excellent use of mechanics, ratio of lever to handle length produces good hand-fed finishes, and round tool bit gives best clearance for light work. You can grind a separate parting bit for thin wall work too.
    I'd be tempted adding a return device by pneumatic or spring, but making this an engine lathe tool is brilliant. Variations are almost exclusive to turret lathes.
  11. #9
    Jun 2018
    Stevohdee's Tools
    Thanks toolmaker 51, now ya got me thinkin, hmm, could have used quick parting tool recently & spring return? Hmm, great input, have thought about increasing travel somehow.
    thanks
    Stevoh
  12. The Following User Says Thank You to Stevohdee For This Useful Post:
    Toolmaker51 (Jun 19, 2018)
  13. #10
    Dec 2017
    Cape Coral, FL
    old_toolmaker's Tools
    Stevohdee,
    Great idea and well executed!!! The tool is solid, compact and not complicated by unnecessary features such as dovetail slides, etc. I love it's simple form and function. I am wanting one for myself.
    Dick
    Links to some of my plans:
  14. The Following User Says Thank You to old_toolmaker For This Useful Post:
    PJs (Jul 23, 2018)
