Results 1 to 10 of 16
Thread: Tapping Stand or Hand Tapper
    jjr2001's Tools
    Inspiration for this one is from Projects In Metal book 3. It was not meant to be an exact duplicate
    but rather a build using materials that I have on hand.
    The tapper includes two tapping spindles at present and more could follow. Either spindle can be driven
    by the tommy bar or the knurled aluminum knob.
    The knurled knobs were made from round bar stock and some flat head screws I had on hand.
    The cotters are made with 3/8 aluminum and differ from the method used in Projects in Metal.
    Cotter details are here:
    http://www.homemadetools.net/forum/m...rt-shaft-71576
    In addition to the two spindles for tapping there is a hole locator also. It should work for most
    material thicknesses with the two ends. If not then I will just make another.
    The Post is 14" long 3/4 inch in diameter drill rod. One groove helps retain it in the column support with
    the addition of two locking knobs.
    The Rails are 5/8" drill rod by 9 1/4" long.
    Spindles are 1/2" diameter drill rod and vary in length.
    I still need to wind a new spring for the spindles, the one from stock is not strong enough.
    The base plate is 6 1/8" x 9" and 5/8 inch thick aluminum plate. The only steel parts are the parts from drill rod.
    Drilling 72 holes can be fun if you have a power tapper. Check out this thread for an inexpensive power tapping system.
    http://www.homemadetools.net/forum/t...ut-close-71605
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Tapping Stand or Hand Tapper-img_2403.jpg   Tapping Stand or Hand Tapper-img_2402.jpg   Tapping Stand or Hand Tapper-img_2401.jpg   Tapping Stand or Hand Tapper-img_2404.jpg   Tapping Stand or Hand Tapper-img_2398.jpg
  2. The Following 23 Users Say Thank You to jjr2001 For This Useful Post:
    Canyonman44 (Sep 27, 2022), Dimitris Polychronis (Sep 4, 2022), doc_kelly (Mar 16, 2020), Harvey Melvin Richards (Feb 19, 2019), high-side (Feb 19, 2019), Home-PC (Mar 29, 2021), johnds (Sep 28, 2022), johnsmachines (Feb 24, 2019), Jon (Feb 18, 2019), kboy0076 (Dec 18, 2022), Metallurg33 (Feb 18, 2019), mr mikey (Sep 5, 2022), old_toolmaker (Feb 18, 2019), Paul Jones (Feb 19, 2019), rossbotics (Feb 18, 2019), Scotsman Hosie (Feb 19, 2019), Seedtick (Feb 18, 2019), Shanty (Feb 18, 2019), superskypilot (Mar 26, 2021), that_other_guy (Feb 18, 2019), Toolmaker51 (Mar 26, 2021), Tule (Feb 19, 2019), zarembak (Apr 8, 2019)
    Dec 2013
    Florida
    rossbotics's Tools
    Nice clean looking job JR.
    Nice work as usual
    Doug
    Comments are always welcome
    Doug
  4. The Following User Says Thank You to rossbotics For This Useful Post:
    jjr2001 (Feb 24, 2019)
    Dec 2017
    Cape Coral, FL
    old_toolmaker's Tools
    jjr2001,
    That is one very nicely made and versatile piece of tooling. Also great looking knurling job!
    Dick
    Links to some of my plans:
  6. The Following User Says Thank You to old_toolmaker For This Useful Post:
    Aug 2018
    that_other_guy's Tools
    Wow. That sure is purdy......
  8. The Following User Says Thank You to that_other_guy For This Useful Post:
    jjr2001's Tools
    Thanks guys for all the nice comments. It is "purdy" and I hope it works as good as it looks!
    Cheers, JR
  10. #6
    Oct 2014
    Northwestern Illinois
    dave_rupp's Tools
    Great looking tapper! I do have one question that may be related to my inexperience. What is the "jam" plate on the vertical adjustment screw for?
    Dave
  11. The Following User Says Thank You to dave_rupp For This Useful Post:
    jjr2001 (Feb 19, 2019)
  12. #7
    jjr2001's Tools
    Hi Dave and thanks for you comments. The plate in addition with the knurled knob are the locking/unlocking
    mechanism for the two "cotters" that lock the horizontal rod assembly to the vertical post. You can get a better idea
    of the system in this post:http://www.homemadetools.net/forum/m...rt-shaft-71576
    You can see the cotters have threads on both ends. The front threads were removed after the 3/4" diameter
    hole was drilled thru both of them. The forward threads were only needed to get the cotters drilled. The yoke or
    jam plate will pull the cotters tight when the knurled knob is tightened.
    Cheers, JR
    Back to the shop.
  13. The Following 2 Users Say Thank You to jjr2001 For This Useful Post:
    betongtaxen (Dec 28, 2021), Home-PC (Mar 29, 2021)
  14. #8
    Thanks jjr2001! We've added your Tapping Stand to our Tapping and Threading category,
  15. The Following User Says Thank You to DIYer For This Useful Post:
  16. #9
    Aug 2016
    wizard69's Tools
    wow - too pretty to use. Seriously it would likely remain on the shelf simply for fear of damaging the fine workmanship in my shop.
  17. The Following User Says Thank You to wizard69 For This Useful Post:
  18. #10
    jjr2001's Tools
    Thanks wizard69, Nope, I will use it. Sometimes it will be weeks or even months before I use some of my shop made tools.
    However, I use them all eventually, try not to mess them up and if they get scratched, Oh Well!
    Can never have too many tools in the Shop!
    Cheers, JR
    Back to the shop.
