On the motor label it should list the 'FRAME' - that is a standardized NEMA classification for the motor's form-factor (length, diameter, shaft diameter, and bolt pattern).
It may be that you can find a motor with the same frame size and RPM and just swap 'em out.
The only rub is, that as you go up in horsepower, oftentimes the frame size will change.
But, then again, most times you can make darn near any motor fit just by drilling a few holes.
Be sure to check the new motor for RPM and shaft diameter - they should both be the same as the existing motor.
One more thing to think about is the wire size, switch rating, and amps load. If you go up to, say, a 3HP motor, you'll be pulling roughly 4 times the amps.
The switch may need to be upsized as might the other wiring.
Finally, the easiest way to fix your problem is to give me the bandsaw and forget the whole project.
