Results 1 to 10 of 322
Thread: 1974 XS/TX650 rebuild
Hybrid View
    Oct 2015
    th62's Tools
    Finished off the stator mount for the PMA today. I bought a couple of slabs of aluminium, thickest I could get was 25mm, so I settled for that. That meant making a 10mm spacer. After waiting ages for the bandsaw to cut the slab down to a size that would fit in the four jaw I chucked the square slab and made it round, dished the underside to clear the crank bearing mount, bored a 60mm hole through the middle and drilled a couple of holes for mounting.
    Next came the spacer: Turned down a 70mm round ally bar to fit inside the stator windings and turned down a couple of locators either side to locate the spacer under the stator and to locate the spacer inside the base, thus making sure the stator is mounted central. Drilled a few more holes and tapped them, then stuck it all together.
    Drilling and tapping all these holes scratched the hell out of the ally, so I mounted spacer and base in the lathe again and used some emery to get rid of the marks.
    Fits on the engine nicely, just have to file a woodruff down to match the 6mm keyway in the rotor to the 5mm keyway in the crank. After that, solder some terminals on the end of the stator leads, yeah I know, I'm a rebel.
    Next job is to turn up a cam for the points. I'm going to convert the twin points system to a single, lots of messing around here trying to get the points firing at the correct intervals.
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-win_20200905_16_52_04_scan.jpg   1974 XS/TX650 rebuild-win_20200905_16_16_10_scan.jpg   1974 XS/TX650 rebuild-win_20200905_15_53_44_scan.jpg   1974 XS/TX650 rebuild-win_20200905_15_53_11_scan.jpg   1974 XS/TX650 rebuild-win_20200905_15_51_53_scan.jpg
    1974 XS/TX650 rebuild-win_20200905_15_50_03_scan.jpg   1974 XS/TX650 rebuild-win_20200905_15_49_36_scan.jpg
  2. The Following 2 Users Say Thank You to th62 For This Useful Post:
    asterix (Jan 12, 2021), Home-PC (Sep 8, 2020)
    Great job. It is always nice to see work done properly.
    Personally I prefer to make new stuff rather than repair old stuff. I cannot imagine taking on a bike so degraded as your starting point. I take my hat off to you.
