Results 1 to 10 of 322
Thread: 1974 XS/TX650 rebuild
Hybrid View
    Oct 2015
    th62's Tools
    Retry: Synced the carbs and checked the PMA today. Bike runs beautifully now, idles nicely, revs cleanly, no spitting or hesitation. PMA/reg/rect output is 14.6 volts, so happy with that as well. Timing is spot on on both cylinders, so the single points cam also works well and the filter and cooler deliver a good oil supply with no leaks. Fancy that, all the engine mods worked as planned! This is my homemade manometer I use for syncing, super easy to use, gives a good, stable reading.
    Now it's back to cycle parts. I was going to spoke the wheels next, but can't get any stainless spokes for the rear wheel, so I'll have to work on something else: I've been thinking of hunting around for a clagged 650 motor, I'm missing working on motors already.
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-manometer2.jpg
  2. The Following User Says Thank You to th62 For This Useful Post:
    asterix (Oct 16, 2021)
