Results 1 to 7 of 7
Thread: 3"kant twist klamp and tap follower with linseed oil finish
    Jan 2016
    Neil Jensen's Tools
    3"kant twist klamp and tap follower with linseed  oil finish-img_20180521_143543.jpgClick image for larger version.
  2. The Following 3 Users Say Thank You to Neil Jensen For This Useful Post:
    Jon (May 22, 2018), PJs (May 23, 2018), Seedtick (May 22, 2018)
    Did you boil the clamps in the linseed oil?
    Jan 2016
    Neil Jensen's Tools
    I heated the parts to about 500 degrees F dipped in linseed oil let dry hour or so then reheated to 500 F for about 30 minutes[until I liked the color
  5. The Following 3 Users Say Thank You to Neil Jensen For This Useful Post:
    12bolts (May 22, 2018), Frank S (May 22, 2018), PJs (May 23, 2018)
    Sep 2012
    Hinchinbrook QLD
    Do you have a kiln or oven? Or did you do this in a furnace?
    Jan 2016
    Neil Jensen's Tools
    I used a propane torch on an earlier attempt worked ok but slow,on these I have a piece of 10" pipe about 18" tall domed on top and a hinged door on front,set on a gas burner for a turkey fryer,I can quickly get a lot of pieces to 500+degrees .You could easily do this in oven or even toaster oven
  8. The Following 2 Users Say Thank You to Neil Jensen For This Useful Post:
    12bolts (May 23, 2018), PJs (May 23, 2018)
    Thanks Neil Jensen! We've added your Kant Twist Clamp to our Clamps category,
    as well as to your builder page: Neil Jensen's Homemade Tools. Your receipt:
  10. #7
    Thanks Neil Jensen! We've added your Tap Follower to our Tapping and Threading category,
