https://youtu.be/mtG7Pqel84Y
Thanks Junkyard! We've added your Spiral Featherboard to our Woodworking category,
as well as to your builder page: Junkyard's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-spiral-featherboard"> <img src="/uploads/252809/homemade-spiral-featherboard.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-spiral-featherboard">Spiral Featherboard</a> <span> by <a href="https://www.homemadetools.net/builder/Junkyard">Junkyard</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/featherboard'>featherboard</a> </div> </div> </div> </div>
Thanks Junkyard! We've added your Dowel Jig to our Jigs category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-dowel-jig-11"> <img src="/uploads/252814/homemade-dowel-jig-11.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-dowel-jig-11">Dowel Jig</a> <span> by <a href="https://www.homemadetools.net/builder/Junkyard">Junkyard</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/jig'>jig</a>, <a href='https://www.homemadetools.net/tag/dowel'>dowel</a> </div> </div> </div> </div>
Thanks Junkyard! We've added your Sheetmetal Cutter to our Metalworking category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-sheetmetal-cutter-5"> <img src="/uploads/252819/homemade-sheetmetal-cutter-5.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-sheetmetal-cutter-5">Sheetmetal Cutter</a> <span> by <a href="https://www.homemadetools.net/builder/Junkyard">Junkyard</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/sheetmetal'>sheetmetal</a>, <a href='https://www.homemadetools.net/tag/cutting-tool'>cutting tool</a> </div> </div> </div> </div>
Thanks Junkyard! We've added your Circle Sanding Jig to our Sanding category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-circle-sanding-jig-6"> <img src="/uploads/252824/homemade-circle-sanding-jig-6.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-circle-sanding-jig-6">Circle Sanding Jig</a> <span> by <a href="https://www.homemadetools.net/builder/Junkyard">Junkyard</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/jig'>jig</a>, <a href='https://www.homemadetools.net/tag/disc-sander'>disc sander</a> </div> </div> </div> </div>
Thanks Junkyard! We've added your Drill Press Small Piece Holder to our Drilling and Drill Presses category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-drill-press-small-piece-holder"> <img src="/uploads/252829/homemade-drill-press-small-piece-holder.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-drill-press-small-piece-holder">Drill Press Small Piece Holder</a> <span> by <a href="https://www.homemadetools.net/builder/Junkyard">Junkyard</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/drill-press'>drill press</a>, <a href='https://www.homemadetools.net/tag/hold-down'>hold down</a> </div> </div> </div> </div>
