Results 1 to 4 of 4
Thread: 60" H spreader bar
    60" H spreader bar
    A project I have been working on for quite some time is near enough to completion that we are going to have to mock mount it in the pickup so we can determine the final mounting for the unit. TO do this I want to be able to lower it into the pickup bed as a single assembly rather than have to disassemble it and re assemble it in the truck then take it apart again to remove put it back together and finish the remaing parts to it
    To do this I need a spreader bar which can lift straight up from the sides and not apply any squeeze pressure
    This is what I made out of some scrap rectangular tubing and some 5/8 sucker rod I have a lot of that rod
    After washing the bits of tubing apart with the torch I was ready to make the spreader bar
    First make the lifting loop
    Next start adding the bracing and sling loops made out of 2 8ft lengths of the rod
    Use an old V pulley as the guide for forming the sling loops
    now to rinse and repeat 3 more times
    Completed spreader bar
    Note how the rods and the lifting loop inter lace
    the sling loops
    I decided to hold off painting it until I get my sand blast booth set up
  2. The Following 5 Users Say Thank You to Frank S For This Useful Post:
    baja (Mar 16, 2022), KustomsbyKent (Mar 15, 2022), semaur (Mar 15, 2022), Toolmaker51 (Mar 15, 2022), ttmrj (Mar 15, 2022)
