Originally Posted by
metric_taper
The problem with silicon rectifiers, they have a negative temperature coefficient (relative to resistance). So when you parallel the diodes, the hottest one has the lowest resistance, and hogs the current, making it hotter, and you end up with thermal runaway.
Circuits that parallel transistors to boost the current capability, put a small value resistor in series with each of their emitter current paths that inhibits the thermal runaway, as there is a voltage feedback from the resistors increased voltage drop, to the current injected into the base of the transistor, to regulate the collector current.
I do like the copper bus bars connecting the bridge rectifiers together.
