Quote Originally Posted by Partimer View Post
I built the jig from wood mag. Works well, although is awkward to clamp on my table. Need to rethink the clamping system.
Had a look at the plan, it looks like the jig is mounted on a Delta 14" saw. Don't know what saw you have but if your saw table is thicker or thinner its a simple matter of matching the side rails (part C & D) to the thickness of your table. Changing the Aluminum clamp fasteners to carriage bolts inserted from above with wing nuts to fasten the clamps might make it easier and faster to add or remove the table. If the problem is something different the system looks easy enough to modify to suit your saw.
Carlos B
