Thread: Air compressor build in progress
  1. #2
    well at long last I finally got around to finishing up my air compressor build the final piece required re bending a work hardened 3/4" copper line
    the compressor is under powered with the motor that is on the unit but it was already mounted with the compressor head when I got it
    I haven't installed piping in my shop yet so no need to run the compressor as of yet I only plugged it in long enough to make sure it will pump air but not long enough to allow it to fully build up a tank full of pressure as the oil in the compressor needs changing
  2. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    EclecticNeophyte (Aug 28, 2025), emu roo (Aug 28, 2025)
