Results 1 to 10 of 10
Thread: Angle grinder tool post grinder / vise mount / stand
    Jyväskylä Finland
    Tuomas's Tools
    Made this kind of mount for angle grinder.
    My friend asked tool post grinder. I decided to build one with other uses too.
    Pictures about the design comes little later.. forgot to resize them.
    Material is stainless 316 and nylon.
    Stand is made from mild steel.
  2. The Following 13 Users Say Thank You to Tuomas For This Useful Post:
    DIYer (Feb 23, 2019), Duke_of_URL (Apr 11, 2019), emu roo (Jul 15, 2024), high-side (Feb 24, 2019), HobieDave (Mar 8, 2020), LMMasterMariner (Feb 21, 2019), Paul Jones (Feb 20, 2019), rossbotics (Feb 24, 2019), sossol (Feb 20, 2019), Steved53 (Feb 20, 2019), that_other_guy (Feb 20, 2019), threesixesinarow (Feb 20, 2019), volodar (Apr 15, 2019)
    Jyväskylä Finland
    Tuomas's Tools
    Here is the pictures and some explanation. Feel free to ask if there is any questions.
    Can be mounted to vise.
    Angle grinder tool post grinder / vise mount / stand-1.jpg
    Angle grinder tool post grinder / vise mount / stand-2.jpg
    Mount is assembled to vise with two M10 screws.
    "Arm", that's the part where this mounting tool is mounted to different objects.
    Is shaped to fit to the vise, that it leans to the body of the vise, which guides, and keeps it straight. This gives straight cuts.
    Angle grinder tool post grinder / vise mount / stand-3.jpg
    Grinder mount:
    Is milled from one piece, then cut to half and turned 90 degrees and weld back together, to save time and material.
    Angle grinder tool post grinder / vise mount / stand-4.jpg
    Axle, that connects "arm" and "grinder mount" together.
    Weld washer on other end, again to save material.
    Angle grinder tool post grinder / vise mount / stand-5.jpg
    M10 thread on other end of the axle.
    Thread is where the "friction lock" connects, and its intentionally off centered.
    Off centering makes steel and rubber washers that are bolted to it, make circular movement.
    If thread would be centered, result instead of producing friction to the arms movement, locking bolt would just tighten or loosen, depending which direction arm is moving.
    Angle grinder tool post grinder / vise mount / stand-6.jpg
    At the side of the axle is filed slot for the locking screw that locks axle and the grinder mount together.
    Angle grinder tool post grinder / vise mount / stand-7.jpg
    Angle grinder tool post grinder / vise mount / stand-8.jpg
    Angle grinder tool post grinder / vise mount / stand-9.jpg
    Angle grinder tool post grinder / vise mount / stand-10.jpg
    Both sides of the angle grinder is M10 threads for the handle.
    Piece of M10 threaded rod is screwed to the other side.
    Angle grinder tool post grinder / vise mount / stand-11.jpg
    Angle grinder tool post grinder / vise mount / stand-12.jpg
    Angle grinder tool post grinder / vise mount / stand-13.jpg
    Filed slot to get tight fit.
    Angle grinder tool post grinder / vise mount / stand-14.jpg
  4. The Following 6 Users Say Thank You to Tuomas For This Useful Post:
    Duke_of_URL (Apr 11, 2019), emu roo (Aug 21, 2025), Jon (Feb 20, 2019), Paul Jones (Feb 20, 2019), that_other_guy (Feb 20, 2019), Toolmaker51 (Mar 30, 2021)
    Jyväskylä Finland
    Tuomas's Tools
    And a little shelf on the vise jaw, to guide for to be cut objects straight.
    Angle grinder tool post grinder / vise mount / stand-15.jpg
    Stand:
    Bend edges as feet's. Weld angle iron on the bottom side, guides sparks behind the stand. (most of.. or atleast some of the.. )
    Angle grinder tool post grinder / vise mount / stand-16.jpg
    Angle grinder tool post grinder / vise mount / stand-17.jpg
    Edge guide is locked to the stand with this M8 bolt.
    Angle grinder tool post grinder / vise mount / stand-18.jpg
    Other bolt comes from the bottom side, and when it keeps other end of the edge guide on straight line,
    it also works as a depth stop.
    Angle grinder tool post grinder / vise mount / stand-19.jpg
    Angle grinder tool post grinder / vise mount / stand-20.jpg
    This can also be used as a tool post grinder on lathe. Originally i made one to my friend, then noticed that it could be useful for me too.
    Video shows the using.
    Thanks.
  6. The Following 5 Users Say Thank You to Tuomas For This Useful Post:
    Duke_of_URL (Apr 11, 2019), emu roo (Aug 21, 2025), haz (Feb 24, 2019), Jon (Feb 20, 2019), Paul Jones (Feb 20, 2019)
  8. The Following 5 Users Say Thank You to Jon For This Useful Post:
    Duke_of_URL (Apr 11, 2019), emu roo (Aug 21, 2025), haz (Feb 24, 2019), rossbotics (Feb 24, 2019), Tuomas (Feb 20, 2019)
    Thanks Tuomas! We've added your Angle Grinder Mount to our Grinding category,
  10. The Following User Says Thank You to DIYer For This Useful Post:
  11. #6
    Tuomas you have made so many unique and useful attachments for the lowly rt angle grinder that I never knew I needed each one seems to be better than the previous great job
  13. #7
    Dec 2013
    Florida
    rossbotics's Tools
    You have found more uses for a right angle grinder than I could possibly imagine, good work
    Doug
    Comments are always welcome
    Doug
  14. The Following User Says Thank You to rossbotics For This Useful Post:
  15. #8
    Jyväskylä Finland
    Tuomas's Tools
    Thank you Frank.
    My friend, that got the first version from this.
    Uses it for shaping stone on the lathe.
    Diamond wheel, pneumatic grinder and cutting fluid.
    It seems to work nicely. I have asked a video about the process, i hope to get it soon.
    I really want a good lathe, needs just to find room for it.
  16. The Following User Says Thank You to Tuomas For This Useful Post:
  17. #9
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by rossbotics View Post
    Doug
    Thank you very much. I think there is still many uses for the angle grinder that i haven't found.
  18. The Following User Says Thank You to Tuomas For This Useful Post:
  19. #10
    I think that's 11 so far.
    We call that 'more tricks than a monkey in a mile of grapevines'
  20. The Following User Says Thank You to Toolmaker51 For This Useful Post:
