Thread: Angle Plates 30-60-90Degrees
    Dec 2013
    Florida
    rossbotics's Tools
    I have some thin angle plates but they are sometimes a little wibbly wobbly if you know what I mean, So I decided to make some quiet a bit thicker for a little more stability.
    They were made from 0-1 Tool Steel, they measure appr..750" X 2.500" X 4.250" hardened and matched ground to within .00015", that's as accurate as my cylinder square is.
    I ground the 30Deg angle on a 5" sine bar which I made, ( It's posted on Homemade Tools.net as well )
    I made the 2.5000" gauge block to set the sine bar from O-1 Tool Steel. ( hardened and very very carefully ground )
    I'm going to eventually make another pair of plates that's 45-45-90 Degrees ( Same Steel )
    Below are some photos
    Thanks for looking
    And Happy Machining
    Doug
    Click hear for a free set of these plans http://www.homemadetools.net/forum/f...B0-plans-46232
    Above photo shows the plates Sitting on the sine bar
    A little closer look
    A little closer yet
    Click hear for a freeset of these plans http://www.homemadetools.net/forum/f...B0-plans-46232
  2. The Following 2 Users Say Thank You to rossbotics For This Useful Post:
    kbalch (Jan 5, 2015), Paul Jones (Jan 3, 2015)
    Great work, rossbotics!
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Doug! I've added your Angle Plates to our Machining and Measuring and Marking categories, as well as to your builder page: rossbotics' Homemade Tools. Your receipt:
