Results 11 to 20 of 28
Thread: auto-balancing bench grinder arbors
    Supporting Member mattthemuppet's Avatar
    Aug 2016
    Walla Walla, WA USA
    mattthemuppet's Tools
    still a bit of a work in progress, but I made these in the hope of balancing a wire wheel which is causing my grinder to vibrate.
    Idea is to have a groove in which some ball bearings are free to rotate and come to rest at the point of lowest effective mass on the wheel, thus balancing it. Well, that's the idea anyway, not quite there yet.
    blank turned and drilled
    reamed to 0.501 or so, slip fit on the arbor. Face relieved so that the arbor only contacts the wheel at its periphery. Not 100% sure why this is necessary, but that's how the original ones are made so..
    first arbor parted off
    one set done - the other set was already made from a previous grinder
    mounted, centered and a groove trepanned for 3/32 balls (for my mtb pedals)
    both sides done, with the bearing covers also parted off from the same blank
    test fit
    balls loaded. After the 1st try, where nothing happened, I cleared out the grease. Still nothing, so I added more balls - 25 on the wire side.
    stone side. This side really didn't need any balancing, ran really smoothly without any balls. Figured I'd add them anyway in case the balance changes over time with wear
    wire wheel side
    the arbors did help reduce vibration a bit, but not eliminate it completely. I'll be cutting the groove to 2x ball width to allow the balls to bunch up to see if that improves things. If not, I cut the groove deeper and use larger bearings for more mass. I'll report back with my findings!
    here's a great article about both the physics and another machinist's trials and tribulations with balancing grinders
    metalmagpie's balancing arbors
  2. The Following 18 Users Say Thank You to mattthemuppet For This Useful Post:
    Andyt (Jan 31, 2020), bigtrev8xl (Aug 15, 2016), C-Bag (Aug 15, 2016), Carnel (Jan 31, 2020), DIYer (Aug 18, 2016), drivermark (Apr 28, 2024), emu roo (Jul 22, 2022), Francis4344 (Jan 31, 2020), high-side (Jan 30, 2020), IAMSatisfied (Jan 30, 2020), janders1957 (Dec 27, 2017), Jon (Feb 26, 2024), mudnducs (Feb 10, 2020), mwmkravchenko (May 10, 2018), Paul Jones (Aug 15, 2016), PJs (Aug 15, 2016), rlm98253 (Dec 26, 2017), sossol (Jan 30, 2020)
