Results 1 to 10 of 17
Thread: Bolt with built-in tensile strain gauge - photo and patent
  1. #9
    Supporting Member McDesign's Avatar
    Sep 2016
    McDesign's Tools
    Check these three slides from that presentation out - the first shows just how little of applied torque actually goes into stretching the bolt - remember, a bolt is a spring that has to be stretched to work.
    Second slide shows the components of a 4-lubricant comparison
    Third slide shows the huge variation between applied torque (first red-marked column) and the tension generated in the bolt (second red-marked column) - only variable was the lubricant or lack thereof.
    Forrest
ID:	25796   Click image for larger version.
ID:	25797   Click image for larger version.
  2. The Following 3 Users Say Thank You to McDesign For This Useful Post:
    Jon (Sep 25, 2018), PJs (Sep 26, 2018), volodar (Apr 9, 2019)
