Hi Hans, The bolts you are referring to do indeed have a name. They are referred to as a "Cup point case hardened steel square head set screw". Found in the Acklands Grainger listings for this type of screw. I'm quite sure that there are many other suppliers that could help finding and supplying them.
I agree with Frank on his concerns about making plans and the level of talent a person might have or not have when using them. Many folks have "there way of doing things and there lies the concern. If something is misunderstood and a problem arises, who is responsible. On the other side of the coin what kind of experience does the person drawing the plans have also?
Personally I would not change one single thing in the design or materials in this project. The build is the way it should be and I would trust it crossing North America, Rockies an all. It is a heavy duty build that will give a sure and confident result. Naturally the installation and removal will have the weight of the components to deal with but that could be easily handled alone with a simple jack system that would bear the weight such as a transmission jack would do for a transmission. If so required. That would depend on the person having to do the installation.
If you look closely at all the well taken pictures of Franks build you should be able to determine all the materials required and pretty much figure out the dimensions with a tape measure, and a truck frame would be handy also. That would also depend on your level of experience also. If you have doubts though and you think some help would be required. You could bring the photos and description to a welder fitter and they could give you a running start on the project. To someone with some knowledge in the trade a picture does tell a thousand words, Sometimes being enough to not really require a plan or drawings. Most truck frames will be similar and the materials and hardness-strength will be common knowledge to a tradesperson. Again, they should respect the build though. Frank has already pointed out that the merits have been proven over thousands of miles without a single problem.
Enjoy your build Hans, Frank was very kind to have shared this and I have no doubt as to the amount of experience he has also shared time & time again with this community. rr
