Thread: Box mount / chain rack
    This framework is for the 3rd addition explosives cargo box and ultimately caused the project to be more costly.
    First off it is made from square and rectangular tubing and angle iron, as opposed to a mostly angle iron framework.
    Checking for fitment and clearances before final welding
    Those hoses will have to be moved, plenty of clearance for the brace
    Just barely enough room may have to rotate the clamp
    plenty of room here, I have just the thing to fill that gap
    Perfect location for the chain rack and tub, told you I had something to fill the gap between the deck plate and the framework, note the pogo pole and its mount
    mounting these folding handle screw binders will clear up a lot of storage space in a side box
    clydeman (Apr 18, 2023)
