Results 1 to 10 of 11
Thread: Cart for my hyd power unit
    While digging around in 1 of my sheds I uncovered an old Pressure washer cart
    This gave me the idea to mount my power unit on it because the size looked to be perfect
  2. The Following 5 Users Say Thank You to Frank S For This Useful Post:
    baja (Aug 24, 2019), Jon (Aug 22, 2019), mwmkravchenko (Aug 24, 2019), Scotty12 (Aug 23, 2019), Seedtick (Aug 23, 2019)
    Marion, Iowa
    metric_taper's Tools
    Your habit of spraying paint on fabricated stuff makes it look store bought.
    So what do you use to clean dirt and oil off this before painting? I assume a pressure wash, but then some sort of solvent that washes the oil film.
    I often use an angle grinder with a wire wheel or cup brush to remove some of the dead paint or decals then I dilute some KBS aquaclean in hot water then just use a solvent brush or a paint brush or an air siphon sprayer. if the stuff has a build up of grease and oil it may take a few applications then spray rinse blow dry and paint
    DIYer (Aug 25, 2019)
    Oct 2012
    Frank
    Very nice unit and I bet it works better than a porta-power.
    Nice Job
    Nelson
    Supporting Member Radioman's Avatar
    Jun 2018
    Massachusetts
    Radioman's Tools
    More info on the power unit?
    I like to get a look under the hood.
    Marion, Iowa
    KBS aquaclean
    That product is pricey. I see the MSDS has three ingredients:
    Potassium Hydroxide
    Ethylene glycol monobutyl ether
    4-nonylphenol branched ethoxylated
    So lye, and two other ingredients are surfactants and solvents.
    The KBS web site indicates the product is eco safe. But you clearly have to worry about toxicity and skin damage.
    The 3rd ingredient, the EU has flagged dangerous to the aquatic environment and regulates its use (first hits when doing a search). You can buy lye, but the other two are industrial sales only. Appear to be Dow Chemicals products, that comes up in a search. So the price is warranted by these ingredients not being common nor cheap to buy by anyone.
    You swear by KBS products, so $18/liter must be worth it. I'm guessing you stock pile the 15liter jug.
    So when I searched for KBS Aquaclean, it must have brought up an Australian web site of theirs, using the link in your tag line brings up a much better price of $22/gal.
  9. #7
    Potassium Hydroxide
    Yes you want to wear rubber gloves especially if your skin is sensitive to such things.
    One word worth mentioning some people think using things full strength means better performance. Just the opposite with this stuff. Dilute it according to directions or you are just pouring money out. it work better with hot water as well.
    I've spilled it full strength on my bare hands and just wiped it off or rinsed it off with no ill effects but I also grew up washing parts in ethel gasoline with my bare hands.
    We used to make our own lye (potassium hydroxide) out of ashes to make soap for washing with when I was a kid
  10. #8
    Quote Originally Posted by Radioman View Post
    It started out as a power unit that hung from the post of your average 10 to 15 ton 4 post automotive truck lift with a 6 to 8 gallon plastic tank only I had installed it on a elevator that I made for some close friends up on Vashon Island WA. after nearly 20 years of use the coupling between the pump and the motor went bad rather than take a chance on finding a machine shop willing to make a new coupling we replaced the whole thing with a new unit. So I brought the old one home with me tossed it in my someday pile
    3Hp hydraulic power unit
  11. #9
    Marion, Iowa
    I purchased a gallon, as I need to remove penetrating oils and such. As well, I'll wash the rusted floor first with this product, then apply the blaster product.
    Your a great sales testimonial for KBS.
  12. #10
    There is a learning curve to almost every product no mater who the manufacture is their paints love moisture such as high humidity but hate oils as do every other paint product I've ever used.
