Results 1 to 10 of 11
Thread: Chain Saw Drill Attachment
    Supporting Member Vyacheslav.Nevolya's Avatar
    Dec 2015
    Ukraine
    Vyacheslav.Nevolya's Tools
    Got not quite what I planned, but despite the shortcomings it works well. I wanted to set the drill equipment right on the engine's cranks, but it turns into the opposite side. Therefore, it was necessary to install through the bus and chain.
    Chain Saw Drill Attachment-20190312_095148.jpg Chain Saw Drill Attachment-20190312_095454.jpg Chain Saw Drill Attachment-20190312_095731.jpg Chain Saw Drill Attachment-20190312_101730.jpg Chain Saw Drill Attachment-20190312_101739.jpg Chain Saw Drill Attachment-20190312_133641.jpg Chain Saw Drill Attachment-20190312_134035.jpg Chain Saw Drill Attachment-20190312_134133.jpg
  2. The Following 2 Users Say Thank You to Vyacheslav.Nevolya For This Useful Post:
    Seedtick (Mar 13, 2019), Tuomas (Mar 15, 2019)
  4. The Following 3 Users Say Thank You to Vyacheslav.Nevolya For This Useful Post:
    saintrain (Apr 7, 2019), Seedtick (Mar 13, 2019), Tuomas (Mar 15, 2019)
  6. The Following 2 Users Say Thank You to Vyacheslav.Nevolya For This Useful Post:
    Supporting Member Al8236's Avatar
    Dec 2014
    Kendall Washington
    Al8236's Tools
    The way you have to hold that looks sketchy as all get out! one slip and you are wrapped up in the chain!
    From the time you're born till' you ride in a hearse, there's nothing so bad it couldn't be worse!
    Jan 2018
    Black Mountain Queensland
    ranald's Tools
    Not detracting from this but it seems really awkward to me and a lot of work made from bits & bobs. I recently sold one that drove straight off the bar. I didn't need it any more as no longer doing any rural fencing where it excelled. Again, Not detracting from this job but I'd be using a cordless drill but then I've already have one.
    Thanks Vyacheslav.Nevolya! We've added your Chainsaw Drill Attachment to our Drilling and Drill Presses category,
    as well as to your builder page: Vyacheslav.Nevolya's Homemade Tools. Your receipt:
  10. #7
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    Quote Originally Posted by Al8236 View Post
    I am inclined to agree, the whole arrangement looks clumsy and did I see the saw's teeth still there? There must be another way to achieve the same end, perhaps a weedwhacker motor through a gearbox?
  11. The Following User Says Thank You to Hans Pearson For This Useful Post:
    Al8236 (Mar 14, 2019)
  12. #8
    Jun 2018
    drill atachment
    Quote Originally Posted by Vyacheslav.Nevolya View Post
    as to why would you not have ground the teeth down on the drive chain
    would not a battery drill do the same job but less expensive
  13. #9
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by Hans Pearson View Post
    Here is another way.
    But this one isn't very fast to remove, and you need another clutch if you want to use it as a chainsaw again.
    I like that "attachment" idea is better, just cover to the chain. ( if it feels reasonable )
    Idea itself is very interesting.
    I like that its now removable add, not " permanent modification ".
  14. #10
    Dec 2015
    Ukraine
    I've heard a lot of criticism. That's the essence of the problem. I build my own house, do everything myself, builders I do not hire. In order to secure wooden beams on the ceiling, steel pins need to be put into concrete. For this purpose it is necessary to make in concrete many openings in diameter of 18 mm. Someone recommends that the best cordless drill is you serious? Holes in concrete with a 18 mm cordless drill? The cordless drill will die in a couple of minutes. The house is not yet connected to the mains, it is necessary to look for a way out of the situation. I had an old broken drill, I decided to connect it to the chainsaw, but provided that the chainsaw remains preserved. So I agree that the design is dangerous and awkward, but its purpose is to drill holes in concrete, and then throw it away and forget. Thank you all for your attention.
  15. The Following User Says Thank You to Vyacheslav.Nevolya For This Useful Post:
    Jon (Mar 15, 2019)
