Hello JR,
Thanks for your reply! As for the hardened dowel pins, it might can found (I'm not 100% sure, because we use metric sizes here). For the set screw I'm afraid that might weaken the frame; the thick side at front of the frame is a bit less than 4.70mm (one hand holds the caliper and the other took the picture), so only a 2mm set screw can be put and the questions are: can the frame withstand the pressure? the set screw can clamp securely the pin in its place? Honestly I don't know!
All the best
Dimitris
