Thread: Compact router table / Horizontal router
    Supporting Member morsa's Avatar
    morsa's Tools
    COMPACT ROUTER TABLE
    I made this compact router table (aka mini router table), using a trim router, because I needed a table for medium cuts, keeping in mind that I have the Craftsman router table (60 x 36 cm) for regular cuts, and the Dremel Rotary Tool Shaper and Router Table (20 x 15 cm) for cutting small parts.
    I used a router table “insert”, although instead of using it as an insert, I used it as a tabletop. In this way, the insert measurements determined the length and width of the table (20 x 19.1 cm), while the height was determined by the height of the trim router (27 cm).
Name:	2- Base of the table.JPG
Name:	3- Trim router atached to the insert.JPG
Name:	4- Slot to fix the fence.JPG
Name:	5- Compact router table ready to use.JPG
    In addition to the split fence included with the insert, I made a continuous fence for cuts where it is most convenient.
Name:	6- Continuous fence.JPG
Name:	7- Examples of cuts.jpg
    HORIZONTAL ROUTER
    On the other hand, by placing the table horizontally, and holding the "insert" vertically, you have a HORIZONTAL ROUTER, which is useful for cutting tenons and mortises.
Name:	8- Screws to fix the plate vertically.JPG
Name:	9- Plate and router fixed.JPG
Name:	10- Horizontal router ready to use.JPG
Name:	11- Examples of cuts.jpg
    Regards.
  2. The Following 2 Users Say Thank You to morsa For This Useful Post:
    butlerandrew (Jan 11, 2023), Jon (Jan 13, 2023)
