Results 1 to 4 of 4
Thread: Cutting a 127mm diameter chamfer with a 12mm radius toolpath.
    Supporting Member Mook's Avatar
    Sep 2023
    UK
    Mook's Tools
    This trick uses the inside of the 6" face mill inserts to cut a true large 45 degree chamfer around the perimeter of a 5" bar end. This is a big timesaver on a cnc saving a toolchange and the toolpath using a small chamfering cutter of around 400mm to one less than 40mm.
  2. The Following 8 Users Say Thank You to Mook For This Useful Post:
    albertq (May 15, 2024), emu roo (Jun 5, 2024), Inflight (Jun 9, 2024), Jon (May 31, 2024), mwmkravchenko (May 19, 2024), nova_robotics (May 15, 2024), Ralphxyz (May 15, 2024), Sleykin (Jun 5, 2024)
    Sep 2018
    nova_robotics's Tools
    That's smart use of the tool right there. This is an example of a hand-coded CNC program knocking probably 30+ seconds off the cycle time. I don't know of any CAM packages that are anywhere near this intelligent. In fact, most of them act like they were dropped on their head.
    However... adaptive toolpath was a revolution in machining and it's impossible for a human to write that by hand.
  4. The Following User Says Thank You to nova_robotics For This Useful Post:
    Mook (May 15, 2024)
    Sep 2023
    UK
    Mook's Tools
    cutting a 127mm diameter chamfer with a 12mm raduis toolpath
    If you are interested in reducing cycle times these videos demonstrate bi-directional milling to 1/2 cycle time & tandem milling to reduce cycle time by 60%.
    Subtitles on please.
    Bi-directional milling.
    Tandem milling.
    Last edited by Mook; May 15, 2024 at 01:14 PM. Reason: advise to turn on subtitles
  6. The Following 2 Users Say Thank You to Mook For This Useful Post:
    Jon (Jun 3, 2024), nova_robotics (May 15, 2024)
    Congratulations Mook - your large chamfer cutting method is the Tool Tip of the Month for May 2024!
    Clever timesaver for a clean chamfer, and the methods for reducing cycle times with bi-directional and tandem milling are nice bonus tips.
    Some more good tool tips from May:
    Countersink Nuts by saintrain
    Miter and Table Saw Finger Savers by Make Things
    Jig Making With Masonite by Make Things
    Locking Spring by 2gsg2_muc
    Bandsaw Tips by Make Things
    Unique Table Saw Cuts With Hardboard by Make Things
    Deburring Electric Metallic Tubing by rgsparber
    Using Glass to Keep Chisels Sharp by Make Things
    Sanding With PVC Pipes by Make Things
    Mook - we've added your Tool Tip to our All Tool Tips of the Month winners post. And, you'll now notice the tool tip award in the awards showcase in your postbit, visible beneath your username:
    And, you'll be receiving a $100 prize, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and prize choice and I'll get it sent over right away.
    Congrats again
