Results 1 to 5 of 5
Thread: Cutting gear teeth using a shaper - GIF
    nova_robotics (Jan 29, 2022), Skun Knuckles (Jan 29, 2022)
    Sep 2013
    Karl_H's Tools
    I have heard it said that the only thing you cannot make with a shaper is a profit.
  4. The Following User Says Thank You to Karl_H For This Useful Post:
    BuffaloJohn (Jan 26, 2022)
    Quote Originally Posted by Karl_H View Post
    Well profit may not be the only thing but it sure is high on the list in today's world at least. but time was if you didn't have a shaper in your machine shop you wern't considered a fully equipped shop
    Karl_H (Jan 24, 2022)
    hemmjo's Tools
    Is it just my eyes of is the edge of the tooth a bit wavy? The space between the teeth also looks too narrow. Perhaps this is a rough cutting process to finish later?
    Cutting gear teeth using a shaper - GIF-screen-shot-2022-01-25-7.36.04-am.png
    There has to be some serious pressure on that cutter when it gets to full depth.
Name:	Screen Shot 2022-01-25 at 7.36.04 AM.png
    You are correct the sides are wavy because they will be finish ground in the final process.
    the cutter only slices away small amounts each pass the gear is rotated left and right in decreasing amounts as the cut deepens until the cut profile is nearly complete
