Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Cutting Large Holes in thick steel
    Supporting Member bobneumann's Avatar
    Jul 2018
    bobneumann's Tools
  2. The Following 47 Users Say Thank You to bobneumann For This Useful Post:
    Andyt (Jun 15, 2022), asterix (Jan 20, 2023), baja (May 22, 2021), bensimmons (May 30, 2021), bigtrev8xl (May 24, 2021), BuffaloJohn (Jan 29, 2023), bustre (May 24, 2021), Carnel (May 22, 2021), CharlesWaugh (Jun 14, 2022), cindysdad (Sep 8, 2022), cognitdiss (Jan 21, 2023), Corm (May 24, 2021), davidschutt (Dec 6, 2024), DIYer (May 21, 2021), DIYSwede (May 23, 2021), elk-a-holic (May 21, 2021), EnginePaul (Jan 21, 2023), flyfr8rs (May 24, 2021), GedB (May 27, 2021), H.L (May 22, 2021), HobieDave (Jun 25, 2021), homey_g (May 31, 2021), Inner (May 21, 2021), johncg (May 29, 2021), johnreich (May 25, 2021), Jon (May 26, 2021), Moldyjim (May 24, 2021), mwmkravchenko (May 21, 2021), natie123 (May 21, 2021), NortonDommi (May 23, 2021), nova_robotics (May 21, 2021), Ralphxyz (Jun 13, 2025), ranald (May 29, 2021), raynjer (Jun 14, 2022), rdarrylb (Jan 21, 2023), RetiredFAE (May 21, 2021), rgsparber (May 23, 2021), rlm98253 (May 21, 2021), saguaro (May 27, 2021), Scotty1 (May 23, 2021), Skun Knuckles (Jun 1, 2021), Sleykin (May 22, 2021), tenncf (Aug 12, 2023), thehomeengineer (May 24, 2021), Thunderbelch (May 24, 2021), tmate3 (Jun 21, 2021), Tule (May 24, 2021)
    Thanks bobneumann! We've added your Steel Plate Hole Cutting Method to our Metalworking category,
    as well as to your builder page: bobneumann's Homemade Tools. Your receipt:
    jdurand's Tools
    I went through a bunch of several name brands that all stripped the threads on that screw-in arbor. I finally removed the pins from one and put bolts through and tightened well.
    These were 4-1/4" saws.
    Oct 2017
    good vid,, i worked in the machine shop at a plant that made tilted gravel shaker units,we made the sides from 3/8-3/4 plate,, we clamped them together and tack welded them..then used starett hole saws ,, we never drilled a chip hole in the side,,most chips came out in long strings, we just pulled out the hole saw,an blew out any remaing chips and kept on sawing,,ran the radial arm drill press lowest it would go 60 RPM.. i think,,good vid but it ran over 10 min and u did not mention your RPM u ran at, so heres your Sam Kinison award,,,OOOOOH,OH,OOH,OOH,OOOOOH,OOH,OOH ,OOOOOH !!!!!
    Apr 2016
    Buffalo, NY
    Hate to burst someone’s bubble but this short cut has been around for a long time.
    Thunderbelch's Avatar
    Jul 2018
    Centurion, ZA
    Thunderbelch's Tools
    That's an excellent tip that many of us have never seen before! Just ignore the toxic negative comments.
  9. The Following 3 Users Say Thank You to Thunderbelch For This Useful Post:
    cognitdiss (Jan 21, 2023), EnginePaul (Jan 21, 2023), saguaro (May 27, 2021)
  10. #7
    While I agree the tip has been around for a long time, it doesn't hurt to be reminded of useful tips from time to time either.
    I also stand with previous comments about the importance of using low RPMs.
    I will also add that using a lubricating coolant when ever feasible is equally as important as the low RPMs especially for increasing the longevity to the cutters.
    As far as being brand agnostic goes we might as well be as probably many of the name brand cutters are most likely made by 2 or 3 manufactures and privately labeled
    Having said that whenever possible I do prefer to buy hole saws with brand names after band saw blades instead of power tool names, which may or may not be any better or any different than the power tool names as well.
  11. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    EnginePaul (Jan 21, 2023), NortonDommi (May 23, 2021)
  12. #8
    Jan 2021
    Thanks for this great tip. As far as I am concerned, this one tip justifies the annual subscription fee.
  13. #9
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Quote Originally Posted by mdhatter3 View Post
    It is new to me so MUCH appreciated. I'm off to my shop to try it out.
    Rick
    Rick
  14. #10
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    Thanks for this one. I have been working steel for many years and did not know this tip.
  15. The Following 2 Users Say Thank You to Hans Pearson For This Useful Post:
    EnginePaul (Jan 21, 2023), johnreich (May 25, 2021)
