Results 1 to 5 of 5
Thread: Deck with steel frame
    Jyväskylä Finland
    Tuomas's Tools
    I made small " morning coffee " deck to my wife during last summer.
    Because i wanted it to look slim and light weighted, i made frame of it used steel.
    Material is 70mm * 50mm tubing, with 5 mm thick wall.
    Deck with steel frame-fb_img_1664959578234.jpgDeck with steel frame-fb_img_1664959586477.jpg
    Blue paint is a base coating. Tubings are also rust protected from the inside.
  2. The Following 2 Users Say Thank You to Tuomas For This Useful Post:
    carloski (Oct 5, 2022), nova_robotics (Oct 5, 2022)
    The split rail axe lamp is a nice touch.
  4. The Following User Says Thank You to Jon For This Useful Post:
    mwmkravchenko (Oct 6, 2022)
    Jyväskylä Finland
    Tuomas's Tools
    Thanks Jon
    I also hided some things under it. To be found, if one decides to look under it.
  6. The Following User Says Thank You to Tuomas For This Useful Post:
    Perth Ontario Canada
    Very nice job Tuomas.
    I used to make a few decks a year. Using wood it could have been even a little bit lighter in appearance. You have less than 2 metres in-between your support rails. 125mm joists is enough for that if they are every 450mm and blocked in-between.
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by mwmkravchenko View Post
    Yep. But it also needed to be sturdy. Here its usual that there's 5 feet high pile wet snow on top of it at the wintertime. So, making wooden one, with same stifness, would have needed much more thicker frame.
