Doing my bit to stay out of the shops or any other crowded place today.
So I have some ali blocks to machine to size. The reason why I have been avoiding this is the fact that
Name:	Gauge base too big.jpg
The base of the dial indicator is too BIG. I can not attach it to the mill spindle and move it up and down to square up the block.
I know I should use and endmill and just run ot 90 deg to the vice as the vice is set up square, but again my mill is too small and I do not have enough of a stroke to get to the bottom of the block.
But I have a plan.
Name:	But I have a Plan.jpg
I can remove this part of the rose cutter and make something to fit there.
And with a bit of scratching in the off-cut box, a bit if welding, grinding, drilling and good old filing it is done.
Name:	Scrap Bin saves the day.jpg
And from the other side.
Name:	From the other side.jpg
And just too prove it actually produces the goods.
Name:	Just checking.jpg
Now no excuse not to stay at home and finish the rest of the blox.
