Thread: Dial Indicator Rod Extensions
    May 2014
    Del Mar, California
    Paul Jones's Tools
    I make my own dial indicator rod extensions from 3/16 diameter O-1 drill rod. These can vary in length from 1” to 6” depending on the application. I hold a 4-48 die in the lathe tailstock die holder to cut the male end and cut 0.050” thread relief at the shoulder to provide a tight fit into the dial indicator. The female end thread is 4-48, threaded approximately 0.030” deep, and the first two threads are drilled out for a tight fit. Some examples of the various uses for the extensions include digital depth indicator extension on a small milling machine, hard to reach measurements with the dial indicator, and adding more travel length to a lathe carriage measurement where each extension is exactly 1” long. Thanks for looking.
Name:	Dial Indicator Extensions with 4-48 Threads.jpg
ID:	2807   Click image for larger version.
Name:	Dial Indicator on Unimat Milling Head.jpg
ID:	2808   Click image for larger version.
Name:	Dial Indicator Extra Long Extension.jpg
ID:	2809   Click image for larger version.
Name:	Extra Extension Avoids Making DI Adjustments.jpg
  2. The Following 3 Users Say Thank You to Paul Jones For This Useful Post:
    Catfish (Jan 21, 2015), jjr2001 (Sep 1, 2016), kbalch (Jan 20, 2015)
