Results 1 to 6 of 6
Thread: DIY METAL/WOOD SCRIBERS AND GRINDER HOLDER!!!
  1. #2
    Those are generally called trammel points. By drilling into the end of the bolts and inserting a tungsten from a tig torch that has been sharpened to a point will stay sharp a lot longer than a common bolt will.
    Set the edge of the trammels on opposite legs of a framing square to use as layout guides for marking stringers for stairs
    NortonDommi (Mar 31, 2022)
